[gdal-dev] GDAL 1.8 - Switch Thrown
Ari Jolma ari.jolma at gmail.com
Mon Jan 31 08:27:17 EST 2011
On 01/30/2011 10:39 PM, Tamas Szekeres wrote:
> Ari,
> Assuming you did mention to compile the Perl bindings with MinGW could
> you describe the steps of the compilation in more detail? (by using
> the files downloaded from http://vbkto.dyndns.org/sdk.) Which packages
> should be installed as the prerequisites of the compilation?
> I admit I'm not an expert in MinGW but it would be quite helpful on my
> side to be able to reproduce the issue you are talking about. I would
> also be curious to know how the perl tests are executed in this case.
Tamas,
First, this page:
http://www.transmissionzero.co.uk/computing/building-dlls-with-mingw/
has an alarming advice: "Therefore [when using stdcall], if you intend
to have binary compatibility between MinGW and MSVC builds of your DLL,
it’s necessary to change the names of the exported functions".
The steps: Download and install your DLL package; download the
respective swig/perl folder (this really should be a separately
downloadable package distro); Edit Makefile.PL to find gdal17.dll; run
perl Makefile.PL; run make.bat.
That assumes of course you have a working perl. Strawberry perl should
be usable as it is MinGW. Also in fact Makefile.PL should find the
import library for which I used gdal17.dll.a, which I created with
pexports and dlltool.
Perl tests are run simply as "make test", which runs the test code
without installing anything.
Jürgen, no I did not yet try .lib.
Ari
> Best regards,
> Tamas
> 2011/1/30 Ari Jolma <ari.jolma at gmail.com <mailto:ari.jolma at gmail.com>>
>     29.1.2011 20:43, Tamas Szekeres kirjoitti:
>>     Ari,
>>     I would be eager to know the exact use case you have. Did you
>>     have some errors provided by the linker in this case?
>     For the stdcall functions I added entries like this
>     _CPLDefaultErrorHandler at 12
>     CPLDefaultErrorHandler = _CPLDefaultErrorHandler at 12
>     to the .def file. I create the .dll.a, which is the import
>     library, with dlltool from the .def.
>     There are no errors from the linker. If I leave the stdcall
>     entries as they are from pexports, i.e., just
>     The linker complains about undefined reference to
>     `CPLDefaultErrorHandler'
>     However, running the Perl tests fail with "The procedure entry
>     point CPLDefaultErrorHandler could not be located in the dynamic
>     link library gdal17.dll". This is no wonder since the Perl
>     bindings GDAL.dll imports CPLDefaultErrorHandler from gdal17.dll.
>     I believe this because I'm misusing the .def file or dlltool does
>     not understand that CPLDefaultErrorHandler is an alias to
>     _CPLDefaultErrorHandler at 12.
>     I saw a web page which seemed to say that this is a known problem
>     in dlltool and it had a small hack for dlltool.c to fix the
>     problem, but I don't find the page just now and I've not yet tried
>     hacking the dlltool.c (it seems quite possible).
>     I think the cdecl functions work ok.
>     If I compile GDAL in MSYS, all functions are exported cdecl.
>     Ari
>>     It would indeed be a problem how the various compilers decorate
>>     their export functions in a different way. It looks like the
>>     __declspec(dllexport) option (this is what is used in GDAL)
>>     provides different names with MSVC and MinGW by default. If we
>>     want to compile the dlls in a portable way we should probably get
>>     back to an alternative method like .def file or "#pragma comment(
>>     linker, "/export:FuncName" )" when exporting the functions.
>>     The article you are referring to describes another way of
>>     providing a portable version that is:
>>     1. Compile the dll as it is now (the functions exported
>>     with__declspec(dllexport))
>>     2. Extract the export functions in a .def file by using pexports
>>     3. Replace the function names with their undecorated names in the
>>     .def file
>>     4. Recompile the dll with this new export definition file.
>>     I'm keen to give it a try if I get some further info about how to
>>     test this on the other side.
>>     Best regards,
>>     Tamas
>>     2011/1/29 Ari Jolma <ari.jolma at gmail.com
>>         Did anybody else try to use the now standard Visual Studio
>>         built GDAL DLL (which was much discussed some time ago here
>>         and is now available from Tamas' site) in a MinGW environment?
>>         I spent some time a week or two ago on the issue, but I had a
>>         hard time, which AFAIK is because the DLL mixes two function
>>         export methods and thus using the standard tools seems
>>         difficult if not impossible (I already downloaded the sources
>>         for latest GNU dlltool and considered hacking it...)
>>         The best page about the issue I found so far is this:
>>         http://wyw.dcweb.cn/stdcall.htm
>>         Anybody have any ideas? Is my observation about the two
>>         export methods correct and why is that?
>>         Ari
>>         On 01/29/2011 04:59 AM, Frank Warmerdam wrote:
>>             Folks,
>>             I have had good success with the GDAL 1.8 upgrade and I
>>             have now thrown
>>             the switch migrating it into the production version of
>>             OSGeo4W.
>>             I have upgraded "gdal", "gdal-python", "gdal-mrsid" and
>>             "gdal-autotest".
>>             I have yet to upgrade the ecw, and sde related drivers,
>>             and I have not
>>             upgraded the java bindings.  I will try to work on them
>>             tomorrow.
>>             The gdal15dll package was created for backward
>>             compatability and should
>>             be automatically pulled in.  It seems to be working fine
>>             for OpenEV.
>>             I would encourage folks building packages to update, and
>>             rebuild them
>>             using the current GDAL.  The GDAL include files in
>>             C:\OSGeo4W\include
>>             and libraries in C:\OSGeo4w\lib should now be for 1.8.
>>             Note that the new GDAL package is built using Visual
>>             Studio 2008
>>             Express instead of 2003.  If you are using the C++ API
>>             this may cause
>>             issues but if you use the C API it should be invisible.
>>             Let me know of problems.
>>             Best regards,
>>         _______________________________________________
>>         gdal-dev mailing list
>>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110131/3a5acdd2/attachment-0001.html
