[gdal-dev] gdalinfo fails on jpeg2000 compressed nitf
Cole, Derek dcole at integrity-apps.com
Fri Jul 1 10:29:29 EDT 2011
Hello,
I have been trying to use the v2 OpenJPEG2000 driver with GDAL to read NITF files that have been compressed with jpeg2000.
When I am trying to actually load these files and display them, my software sometimes succeeds, sometimes fails, sometimes gives bogus results. I also occaisionally get a dump like this:
ERROR 1: Marker is not compliant with its position
ERROR 1: opj_read_header() failed
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
I have tried to use gdalinfo on the image in question, and get the following:
ERROR 4: `P003.ntf' not recognised as a supported file format.
ERROR 1: Unable to open JPEG2000 image within NITF file.
Is the JP2KAK driver available?
gdalinfo failed - unable to open 'P003.ntf'.
Any ideas why it seems to be looking for JP2KAK there? I was trying to not use the kakadu driver, because it is not free. Also seems weird to me that the image does load sometimes, and not others. Very buggy feeling.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110701/5b35d4c0/attachment-0001.html
