[gdal-dev] OGR : OCI driver improvement
Nicolas Simon nicolas.simon at spw.wallonie.be
Mon Jul 4 08:32:42 EDT 2011
Hi all,
I'd like to propose some OCI driver improvement.
1) Enable insert from different client. This could be done by managing the generation of new FID on DB side instead of client side.
Technically this could be done with an oracle sequence and a trigger to fill the FID.
This proposition modify the way FID are handled ( I propose to do as in PostGIS driver). This means that the FID of a feature (i.e. usually the value of the OGC_FID column for the feature) inserted into a table with CreateFeature() will be retrieved from the database and can be obtained with GetFID() even if an non-null FID was provided.
This could be easily implemented in UnboundCreateFeature with a 'returning' clause.
But I don't known if it's feasible in BoundCreateFeature since truth FIDs will be know later when OGROCITableLayer::FlushPendingFeatures() is called.
2) By providing true update operation instead of delete + insert operations (cf SetFeture).
This should provide better performance and enable to develop trigger on update if needed for other purpose.
With this modification, OCI driver will have the following mapping between OGR concepts and Oracle operations:
    OGRFeature::CreateFeature() <==> INSERT operation
    OGRFeature::SetFeature() <==> UPDATE operation
    OGRFeature::DeleteFeature() <==> DELETE operation
This modify slightly the actual behavior since it disable the possibility of inserting a new record through SetFeature (in case of  they were no record to delete, the subsequent insert did the job). With the proposed implementation it'll be no longer the case.  "Update ... set ...  where FID = provided FID" command doesn't insert new record.
3) Add transaction support in the normal SQL sense.
Since transaction is handled within a session and we have a session per OGROCIDataSource, a transaction will include operation on any layer of that datasource.
I propose the following operating mode.
Outside a transaction, we'll be in 'auto commit' mode.
  This commit on success DeleteFeature, SetFeature and CreateFeature (not in MULTI_LOAD mode).
  For CreateFeature (in MULTI_LOAD mode) data will be commited
  - each time the buffer is full (when OGROCITableLayer::FlushPendingFeatures() is called)
  - when OGROCITableLayer::SyncToDisk() is call
  - before a new transaction start.
Transaction start (through a call OGRLayer::StartTransaction()) for all layer in the DataSource.
OGRLayer::CommitTransaction() will call OGROCITableLayer::SyncToDisk() for each layer of  the DataSource and issues one commit command for the session, and then return in auto commit mode (cf outside transaction mechanism)
OGRLayer::RollbackTransaction() will drop PendingFeature (may be  through a private function that reset nWriteCacheUsed to 0) for each layer of the datasource and issues one rollback command for the session, and then return to auto commit mode.
I would like to know if someone else is interested in these improvements ?
Is it the way you want things work ?
An other information is that I'm ready to work for these improvements.
Regards,
Nicolas
Nicolas Simon, Informaticien
Service Public de Wallonie (SPW)
Direction générale opérationnelle Agriculture, Ressources Naturelles et Environnement (DGARNE)
Département des Aides
Direction de l'Octroi des Aides agricoles - Service Informatique
14, Chaussée de Louvain - 4e étage
5000 Namur
BELGIUM
