[gdal-dev] Add capability to safely link against an external libtiff (3.X) and a GDAL build with internal libtiff (4.0) support
Antonio Valentino antonio.valentino at tiscali.it
Mon Jul 4 13:43:17 EDT 2011
Hi Even,
Il 03/07/2011 19:02, Even Rouault ha scritto:
>> Do you have some particular indication about how to test it?
>> Which test programs did you use?
> My tests mainly consisted in checking that GDAL would compile and link
> successfully with various combinations of the configure options.
> With the renaming options enabled, I did a "objdump -t libgdal.so | awk
> '{print $6}' | grep TIFF | grep -v TIFFjpeg_ | grep -v aig_ | grep -v gdal_ |
> sort -u" to ensure that all the symbols that should be renamed are. You will
> notice a few remaining occurrences but I think they are safe.
> Also, when the renaming options where enabled, I added -ltiff -lgeotiff to the
> gdalinfo linking line, before or after -lgdal, and tested the executable on a
> few files.
Even, all tests i performed (ubuntu 11.04 only) passed successfully so I
can confirm that the patch works.
My only concern is that I'm not able to reproduce the crash in cases in
which GDAL is built without symbol renaming.
Anyway I have still not tried test programs suggested by Julien.
regards
Antonio Valentino
