[gdal-dev] Add capability to safely link against an external libtiff (3.X) and a GDAL build with internal libtiff (4.0) support
Antonio Valentino antonio.valentino at tiscali.it
Mon Jul 4 14:15:19 EDT 2011
Hi Julien,
Il 04/07/2011 20:02, MALIK Julien ha scritto:
> A good place to look for would be the debian package compilation
> options, since this is where the problem can be seen (it has at least
> --with-hide-internal-symbols).
> Julien
Thanks Julien.
I also found some sparse information in the debian bug tracking system.
P.S:: congratulations for the release of OTB 3.10 :)
> Quoting Even Rouault <even.rouault at mines-paris.org>:
>>> Even, all tests i performed (ubuntu 11.04 only) passed successfully so I
>>> can confirm that the patch works.
>> Great
>>> My only concern is that I'm not able to reproduce the crash in cases in
>>> which GDAL is built without symbol renaming.
>> Hum, did you activate --with-hide-internal-symbols ? I somehow
>> remember that
>> it paradoxically helped revealing the duplicate symbol issues.
Antonio Valentino
