[gdal-dev] upside flipped NetCDF
bonushenricus bonushenricus at linux.it
Mon Jul 4 17:42:40 EDT 2011
Hello,
I'm working on NetCDF weather data.  I tried importing it in GRASS
6.3 via GDAL version 1.6.3 on Debian 6.0. It worked, but the result
was flipped on the horizontal axis.
Could you help me understand what's happening?
The text rendition of my NetCDF file follows.
netcdf ACRR_201105040830_001H {
dimensions:
        xc = 41 ;
        yc = 41 ;
        time = UNLIMITED ; // (1 currently)
        geo_dim = 4 ;
        mesh_dim = 2 ;
variables:
        float xc(xc) ;
                xc:axis = "X" ;
                xc:long_name = "X Coordinate of projection" ;
                xc:units = "meters" ;
                xc:standard_name = "projection_x_coordinate" ;
        float yc(yc) ;
                yc:axis = "Y" ;
                yc:long_name = "Y Coordinate of projection" ;
                yc:units = "meters" ;
                yc:standard_name = "projection_y_coordinate" ;
        float lon(yc, xc) ;
                lon:long_name = "longitude" ;
                lon:units = "degrees_east" ;
                lon:standard_name = "longitude" ;
        float lat(yc, xc) ;
                lat:long_name = "latitude" ;
                lat:units = "degrees_north" ;
                lat:standard_name = "latitude" ;
        float time(time) ;
                time:long_name = "time" ;
                time:units = "hour since 2011-05-04 08:30:0" ;
        char idl ;
                idl:projection_name = "UTM" ;
                idl:projection_index = 101s ;
                idl:grid_mapping_name = "idl-UTM" ;
                idl:center_longitude = 11.6199998855591 ;
                idl:center_latitude = 44.6500015258789 ;
                idl:zone = 32. ;
        float geo_limits(geo_dim) ;
                geo_limits:long_name = "Geo limits [yLL,xLL,yUR,xUR]" ;
                geo_limits:units = "meters" ;
        float grid_mesh(mesh_dim) ;
                grid_mesh:long_name = "Grid Mesh Size [X_mesh_size,
Y_mesh_size]" ;
        float cum_pr_mm(yc, xc) ;
                cum_pr_mm:long_name = "Radar Precipitation amount" ;
                cum_pr_mm:units = "mm" ;
                cum_pr_mm:standard_name = "precipitation_amount" ;
                cum_pr_mm:valid_min = 0.f ;
                cum_pr_mm:valid_max = 10000.f ;
                cum_pr_mm:coordinates = "lat lon" ;
                cum_pr_mm:grid_mapping = "idl-UTM" ;
                cum_pr_mm:detection_minimum = "      0.00000" ;
                cum_pr_mm:undetectable = "      0.00000" ;
                cum_pr_mm:var_missing = "   -0.0100000" ;
                cum_pr_mm:accum_time_h = 1.f ;
// global attributes:
                :Conventions = "CF-1.4" ;
                :history = "Created by write_rad2d_netcdf.pro" ;
                :institute = "ARPA ER - SIMC " ;
                :title = "Radar product" ;
                :reference = "palberoni at arpa.emr.it" ;
                :comment = "none" ;
                :MapType = "SRT" ;
                :RADARS_NAME = "" ;
data:
xc = 649000, 650000, 651000, 652000, 653000, 654000, 655000, 656000,
657000,
    658000, 659000, 660000, 661000, 662000, 663000, 664000, 665000,
666000,
    667000, 668000, 669000, 670000, 671000, 672000, 673000, 674000,
675000,
    676000, 677000, 678000, 679000, 680000, 681000, 682000, 683000,
684000,
    685000, 686000, 687000, 688000, 689000 ;
yc = 4941000, 4942000, 4943000, 4944000, 4945000, 4946000, 4947000,
4948000,
    4949000, 4950000, 4951000, 4952000, 4953000, 4954000, 4955000,
4956000,
    4957000, 4958000, 4959000, 4960000, 4961000, 4962000, 4963000,
4964000,
    4965000, 4966000, 4967000, 4968000, 4969000, 4970000, 4971000,
4972000,
    4973000, 4974000, 4975000, 4976000, 4977000, 4978000, 4979000,
4980000,
    4981000 ;
lon =
  10.8777, 10.8903, 10.90289, 10.91549, 10.92808, 10.94068, 10.95327,
    10.96587, 10.97846, 10.99106, 11.00365, 11.01624, 11.02884,
11.04143,
    11.05402, 11.06662, 11.07921, 11.0918, 11.1044, 11.11699, 11.12958,
    11.14217, 11.15477, 11.16736, 11.17995, 11.19254, 11.20513,
11.21772,
    11.23032, 11.24291, 11.2555, 11.26809, 11.28068, 11.29327, 11.30586,
    11.31845, 11.33104, 11.34363, 11.35622, 11.36881, 11.3814,
  10.87799, 10.89059, 10.90319, 10.91579, 10.92838, 10.94098, 10.95358,
    10.96617, 10.97877, 10.99136, 11.00396, 11.01656, 11.02915,
11.04175,
    11.05434, 11.06694, 11.07953, 11.09213, 11.10472, 11.11732,
11.12991,
    11.14251, 11.1551, 11.16769, 11.18029, 11.19288, 11.20547, 11.21807,
    11.23066, 11.24325, 11.25585, 11.26844, 11.28103, 11.29362,
11.30622,
    11.31881, 11.3314, 11.34399, 11.35658, 11.36917, 11.38177,
  10.87828, 10.89088, 10.90348, 10.91608, 10.92868, 10.94128, 10.95388,
    10.96648, 10.97907, 10.99167, 11.00427, 11.01687, 11.02946,
11.04206,
    11.05466, 11.06726, 11.07985, 11.09245, 11.10505, 11.11764,
11.13024,
    11.14284, 11.15543, 11.16803, 11.18062, 11.19322, 11.20582,
11.21841,
    11.23101, 11.2436, 11.2562, 11.26879, 11.28138, 11.29398, 11.30657,
    11.31917, 11.33176, 11.34435, 11.35695, 11.36954, 11.38213,
  10.87858, 10.89118, 10.90378, 10.91638, 10.92898, 10.94158, 10.95418,
    10.96678, 10.97938, 10.99198, 11.00458, 11.01718, 11.02978,
11.04238,
    11.05498, 11.06758, 11.08018, 11.09277, 11.10537, 11.11797,
11.13057,
    11.14317, 11.15577, 11.16836, 11.18096, 11.19356, 11.20616,
11.21875,
    11.23135, 11.24395, 11.25654, 11.26914, 11.28174, 11.29433,
11.30693,
    11.31952, 11.33212, 11.34472, 11.35731, 11.36991, 11.3825,
  10.87887, 10.89147, 10.90407, 10.91667, 10.92928, 10.94188, 10.95448,
    10.96708, 10.97969, 10.99229, 11.00489, 11.01749, 11.03009,
11.04269,
    11.05529, 11.0679, 11.0805, 11.0931, 11.1057, 11.1183, 11.1309,
11.1435,
    11.1561, 11.1687, 11.1813, 11.1939, 11.2065, 11.2191, 11.2317,
11.24429,
    11.25689, 11.26949, 11.28209, 11.29469, 11.30729, 11.31988,
11.33248,
    11.34508, 11.35768, 11.37027, 11.38287,
  10.87916, 10.89176, 10.90437, 10.91697, 10.92957, 10.94218, 10.95478,
    10.96739, 10.97999, 10.9926, 11.0052, 11.0178, 11.03041, 11.04301,
    11.05561, 11.06822, 11.08082, 11.09342, 11.10602, 11.11863,
11.13123,
    11.14383, 11.15643, 11.16903, 11.18163, 11.19424, 11.20684,
11.21944,
    11.23204, 11.24464, 11.25724, 11.26984, 11.28244, 11.29504,
11.30764,
    11.32024, 11.33284, 11.34544, 11.35804, 11.37064, 11.38324,
  10.87945, 10.89205, 10.90466, 10.91727, 10.92987, 10.94248, 10.95509,
    10.96769, 10.9803, 10.9929, 11.00551, 11.01812, 11.03072, 11.04333,
    11.05593, 11.06854, 11.08114, 11.09375, 11.10635, 11.11895,
11.13156,
    11.14416, 11.15677, 11.16937, 11.18197, 11.19458, 11.20718,
11.21978,
    11.23239, 11.24499, 11.25759, 11.27019, 11.28279, 11.2954, 11.308,
    11.3206, 11.3332, 11.3458, 11.35841, 11.37101, 11.38361,
  10.87974, 10.89235, 10.90495, 10.91756, 10.93017, 10.94278, 10.95539,
    10.968, 10.9806, 10.99321, 11.00582, 11.01843, 11.03103, 11.04364,
    11.05625, 11.06886, 11.08146, 11.09407, 11.10668, 11.11928,
11.13189,
    11.14449, 11.1571, 11.1697, 11.18231, 11.19492, 11.20752, 11.22013,
    11.23273, 11.24534, 11.25794, 11.27054, 11.28315, 11.29575,
11.30836,
    11.32096, 11.33356, 11.34617, 11.35877, 11.37137, 11.38398,
  10.88003, 10.89264, 10.90525, 10.91786, 10.93047, 10.94308, 10.95569,
    10.9683, 10.98091, 10.99352, 11.00613, 11.01874, 11.03135, 11.04396,
    11.05657, 11.06918, 11.08178, 11.09439, 11.107, 11.11961, 11.13222,
    11.14482, 11.15743, 11.17004, 11.18265, 11.19526, 11.20786,
11.22047,
    11.23308, 11.24568, 11.25829, 11.2709, 11.2835, 11.29611, 11.30871,
    11.32132, 11.33392, 11.34653, 11.35913, 11.37174, 11.38434,
  10.88032, 10.89293, 10.90555, 10.91816, 10.93077, 10.94338, 10.95599,
    10.96861, 10.98122, 10.99383, 11.00644, 11.01905, 11.03166,
11.04427,
    11.05689, 11.0695, 11.08211, 11.09472, 11.10733, 11.11994, 11.13255,
    11.14516, 11.15777, 11.17038, 11.18299, 11.19559, 11.2082, 11.22081,
    11.23342, 11.24603, 11.25864, 11.27125, 11.28386, 11.29646,
11.30907,
    11.32168, 11.33429, 11.34689, 11.3595, 11.37211, 11.38471,
  10.88061, 10.89323, 10.90584, 10.91846, 10.93107, 10.94368, 10.9563,
    10.96891, 10.98152, 10.99414, 11.00675, 11.01937, 11.03198,
11.04459,
    11.0572, 11.06982, 11.08243, 11.09504, 11.10765, 11.12027, 11.13288,
    11.14549, 11.1581, 11.17071, 11.18332, 11.19594, 11.20855, 11.22116,
    11.23377, 11.24638, 11.25899, 11.2716, 11.28421, 11.29682, 11.30943,
    11.32204, 11.33465, 11.34726, 11.35987, 11.37247, 11.38508,
  10.8809, 10.89352, 10.90614, 10.91875, 10.93137, 10.94398, 10.9566,
    10.96922, 10.98183, 10.99445, 11.00706, 11.01968, 11.03229,
11.04491,
    11.05752, 11.07014, 11.08275, 11.09537, 11.10798, 11.12059,
11.13321,
    11.14582, 11.15844, 11.17105, 11.18366, 11.19628, 11.20889, 11.2215,
    11.23411, 11.24673, 11.25934, 11.27195, 11.28456, 11.29717,
11.30979,
    11.3224, 11.33501, 11.34762, 11.36023, 11.37284, 11.38545,
  10.88119, 10.89381, 10.90643, 10.91905, 10.93167, 10.94429, 10.9569,
    10.96952, 10.98214, 10.99476, 11.00737, 11.01999, 11.03261,
11.04523,
    11.05784, 11.07046, 11.08307, 11.09569, 11.10831, 11.12092,
11.13354,
    11.14615, 11.15877, 11.17139, 11.184, 11.19662, 11.20923, 11.22185,
    11.23446, 11.24707, 11.25969, 11.2723, 11.28492, 11.29753, 11.31014,
    11.32276, 11.33537, 11.34798, 11.3606, 11.37321, 11.38582,
  10.88149, 10.89411, 10.90673, 10.91935, 10.93197, 10.94459, 10.95721,
    10.96983, 10.98245, 10.99507, 11.00768, 11.0203, 11.03292, 11.04554,
    11.05816, 11.07078, 11.0834, 11.09602, 11.10863, 11.12125, 11.13387,
    11.14649, 11.1591, 11.17172, 11.18434, 11.19696, 11.20957, 11.22219,
    11.23481, 11.24742, 11.26004, 11.27265, 11.28527, 11.29789, 11.3105,
    11.32312, 11.33573, 11.34835, 11.36096, 11.37358, 11.38619,
  10.88178, 10.8944, 10.90702, 10.91964, 10.93227, 10.94489, 10.95751,
    10.97013, 10.98275, 10.99537, 11.008, 11.02062, 11.03324, 11.04586,
    11.05848, 11.0711, 11.08372, 11.09634, 11.10896, 11.12158, 11.1342,
    11.14682, 11.15944, 11.17206, 11.18468, 11.1973, 11.20992, 11.22253,
    11.23515, 11.24777, 11.26039, 11.27301, 11.28563, 11.29824,
11.31086,
    11.32348, 11.33609, 11.34871, 11.36133, 11.37395, 11.38656,
  10.88207, 10.89469, 10.90732, 10.91994, 10.93257, 10.94519, 10.95781,
    10.97044, 10.98306, 10.99568, 11.00831, 11.02093, 11.03355,
11.04618,
    11.0588, 11.07142, 11.08404, 11.09667, 11.10929, 11.12191, 11.13453,
    11.14715, 11.15977, 11.1724, 11.18502, 11.19764, 11.21026, 11.22288,
    11.2355, 11.24812, 11.26074, 11.27336, 11.28598, 11.2986, 11.31122,
    11.32384, 11.33646, 11.34908, 11.36169, 11.37431, 11.38693,
  10.88236, 10.89499, 10.90761, 10.92024, 10.93287, 10.94549, 10.95812,
    10.97074, 10.98337, 10.99599, 11.00862, 11.02124, 11.03387,
11.04649,
    11.05912, 11.07174, 11.08437, 11.09699, 11.10962, 11.12224,
11.13486,
    11.14749, 11.16011, 11.17273, 11.18536, 11.19798, 11.2106, 11.22322,
    11.23585, 11.24847, 11.26109, 11.27371, 11.28633, 11.29896,
11.31158,
    11.3242, 11.33682, 11.34944, 11.36206, 11.37468, 11.3873,
  10.88265, 10.89528, 10.90791, 10.92054, 10.93317, 10.94579, 10.95842,
    10.97105, 10.98368, 10.9963, 11.00893, 11.02156, 11.03419, 11.04681,
    11.05944, 11.07206, 11.08469, 11.09732, 11.10994, 11.12257,
11.13519,
    11.14782, 11.16045, 11.17307, 11.18569, 11.19832, 11.21094,
11.22357,
    11.23619, 11.24882, 11.26144, 11.27407, 11.28669, 11.29931,
11.31194,
    11.32456, 11.33718, 11.3498, 11.36243, 11.37505, 11.38767,
  10.88295, 10.89558, 10.90821, 10.92084, 10.93347, 10.9461, 10.95873,
    10.97136, 10.98398, 10.99661, 11.00924, 11.02187, 11.0345, 11.04713,
    11.05976, 11.07239, 11.08501, 11.09764, 11.11027, 11.1229, 11.13553,
    11.14815, 11.16078, 11.17341, 11.18603, 11.19866, 11.21129,
11.22391,
    11.23654, 11.24917, 11.26179, 11.27442, 11.28704, 11.29967,
11.31229,
    11.32492, 11.33754, 11.35017, 11.36279, 11.37542, 11.38804,
  10.88324, 10.89587, 10.9085, 10.92113, 10.93377, 10.9464, 10.95903,
    10.97166, 10.98429, 10.99692, 11.00955, 11.02219, 11.03482,
11.04745,
    11.06008, 11.07271, 11.08534, 11.09797, 11.1106, 11.12323, 11.13586,
    11.14849, 11.16112, 11.17375, 11.18637, 11.199, 11.21163, 11.22426,
    11.23689, 11.24952, 11.26214, 11.27477, 11.2874, 11.30003, 11.31265,
    11.32528, 11.33791, 11.35053, 11.36316, 11.37579, 11.38841,
  10.88353, 10.89617, 10.9088, 10.92143, 10.93407, 10.9467, 10.95933,
    10.97197, 10.9846, 10.99723, 11.00987, 11.0225, 11.03513, 11.04777,
    11.0604, 11.07303, 11.08566, 11.09829, 11.11093, 11.12356, 11.13619,
    11.14882, 11.16145, 11.17408, 11.18671, 11.19934, 11.21198,
11.22461,
    11.23724, 11.24987, 11.2625, 11.27512, 11.28775, 11.30038, 11.31301,
    11.32564, 11.33827, 11.3509, 11.36353, 11.37616, 11.38878,
  10.88382, 10.89646, 10.9091, 10.92173, 10.93437, 10.947, 10.95964,
    10.97227, 10.98491, 10.99755, 11.01018, 11.02281, 11.03545,
11.04808,
    11.06072, 11.07335, 11.08599, 11.09862, 11.11125, 11.12389,
11.13652,
    11.14915, 11.16179, 11.17442, 11.18705, 11.19969, 11.21232,
11.22495,
    11.23758, 11.25021, 11.26285, 11.27548, 11.28811, 11.30074,
11.31337,
    11.326, 11.33863, 11.35126, 11.3639, 11.37653, 11.38916,
  10.88412, 10.89676, 10.90939, 10.92203, 10.93467, 10.94731, 10.95994,
    10.97258, 10.98522, 10.99786, 11.01049, 11.02313, 11.03577, 11.0484,
    11.06104, 11.07368, 11.08631, 11.09895, 11.11158, 11.12422,
11.13685,
    11.14949, 11.16212, 11.17476, 11.18739, 11.20003, 11.21266, 11.2253,
    11.23793, 11.25056, 11.2632, 11.27583, 11.28847, 11.3011, 11.31373,
    11.32637, 11.339, 11.35163, 11.36426, 11.37689, 11.38953,
  10.88441, 10.89705, 10.90969, 10.92233, 10.93497, 10.94761, 10.96025,
    10.97289, 10.98553, 10.99817, 11.01081, 11.02344, 11.03608,
11.04872,
    11.06136, 11.074, 11.08664, 11.09927, 11.11191, 11.12455, 11.13719,
    11.14982, 11.16246, 11.1751, 11.18773, 11.20037, 11.21301, 11.22564,
    11.23828, 11.25091, 11.26355, 11.27619, 11.28882, 11.30146,
11.31409,
    11.32673, 11.33936, 11.352, 11.36463, 11.37726, 11.3899,
  10.8847, 10.89735, 10.90999, 10.92263, 10.93527, 10.94791, 10.96055,
    10.9732, 10.98584, 10.99848, 11.01112, 11.02376, 11.0364, 11.04904,
    11.06168, 11.07432, 11.08696, 11.0996, 11.11224, 11.12488, 11.13752,
    11.15016, 11.1628, 11.17544, 11.18807, 11.20071, 11.21335, 11.22599,
    11.23863, 11.25126, 11.2639, 11.27654, 11.28918, 11.30182, 11.31445,
    11.32709, 11.33973, 11.35236, 11.365, 11.37763, 11.39027,
  10.885, 10.89764, 10.91028, 10.92293, 10.93557, 10.94822, 10.96086,
    10.9735, 10.98615, 10.99879, 11.01143, 11.02407, 11.03672, 11.04936,
    11.062, 11.07464, 11.08729, 11.09993, 11.11257, 11.12521, 11.13785,
    11.15049, 11.16313, 11.17577, 11.18841, 11.20105, 11.21369,
11.22634,
    11.23898, 11.25162, 11.26425, 11.27689, 11.28953, 11.30217,
11.31481,
    11.32745, 11.34009, 11.35273, 11.36537, 11.378, 11.39064,
  10.88529, 10.89794, 10.91058, 10.92323, 10.93587, 10.94852, 10.96116,
    10.97381, 10.98645, 10.9991, 11.01174, 11.02439, 11.03703, 11.04968,
    11.06232, 11.07497, 11.08761, 11.10025, 11.1129, 11.12554, 11.13818,
    11.15083, 11.16347, 11.17611, 11.18876, 11.2014, 11.21404, 11.22668,
    11.23932, 11.25197, 11.26461, 11.27725, 11.28989, 11.30253,
11.31517,
    11.32781, 11.34045, 11.35309, 11.36573, 11.37837, 11.39101,
  10.88558, 10.89823, 10.91088, 10.92353, 10.93617, 10.94882, 10.96147,
    10.97412, 10.98676, 10.99941, 11.01206, 11.0247, 11.03735, 11.05,
    11.06264, 11.07529, 11.08793, 11.10058, 11.11323, 11.12587,
11.13852,
    11.15116, 11.16381, 11.17645, 11.1891, 11.20174, 11.21438, 11.22703,
    11.23967, 11.25232, 11.26496, 11.2776, 11.29025, 11.30289, 11.31553,
    11.32818, 11.34082, 11.35346, 11.3661, 11.37875, 11.39139,
  10.88588, 10.89853, 10.91118, 10.92383, 10.93648, 10.94913, 10.96177,
    10.97442, 10.98707, 10.99972, 11.01237, 11.02502, 11.03767,
11.05032,
    11.06296, 11.07561, 11.08826, 11.10091, 11.11355, 11.1262, 11.13885,
    11.1515, 11.16414, 11.17679, 11.18944, 11.20208, 11.21473, 11.22738,
    11.24002, 11.25267, 11.26531, 11.27796, 11.2906, 11.30325, 11.31589,
    11.32854, 11.34118, 11.35383, 11.36647, 11.37912, 11.39176,
  10.88617, 10.89882, 10.91148, 10.92413, 10.93678, 10.94943, 10.96208,
    10.97473, 10.98738, 11.00003, 11.01268, 11.02533, 11.03798,
11.05064,
    11.06329, 11.07594, 11.08858, 11.10123, 11.11388, 11.12653,
11.13918,
    11.15183, 11.16448, 11.17713, 11.18978, 11.20243, 11.21507,
11.22772,
    11.24037, 11.25302, 11.26567, 11.27831, 11.29096, 11.30361,
11.31625,
    11.3289, 11.34155, 11.35419, 11.36684, 11.37949, 11.39213,
  10.88647, 10.89912, 10.91177, 10.92443, 10.93708, 10.94973, 10.96239,
    10.97504, 10.98769, 11.00035, 11.013, 11.02565, 11.0383, 11.05095,
    11.06361, 11.07626, 11.08891, 11.10156, 11.11421, 11.12686,
11.13952,
    11.15217, 11.16482, 11.17747, 11.19012, 11.20277, 11.21542,
11.22807,
    11.24072, 11.25337, 11.26602, 11.27867, 11.29132, 11.30397,
11.31662,
    11.32926, 11.34191, 11.35456, 11.36721, 11.37986, 11.3925,
  10.88676, 10.89942, 10.91207, 10.92473, 10.93738, 10.95004, 10.96269,
    10.97535, 10.988, 11.00066, 11.01331, 11.02597, 11.03862, 11.05127,
    11.06393, 11.07658, 11.08924, 11.10189, 11.11454, 11.1272, 11.13985,
    11.1525, 11.16516, 11.17781, 11.19046, 11.20311, 11.21576, 11.22842,
    11.24107, 11.25372, 11.26637, 11.27902, 11.29167, 11.30433,
11.31698,
    11.32963, 11.34228, 11.35493, 11.36758, 11.38023, 11.39288,
  10.88705, 10.89971, 10.91237, 10.92503, 10.93768, 10.95034, 10.963,
    10.97566, 10.98831, 11.00097, 11.01363, 11.02628, 11.03894,
11.05159,
    11.06425, 11.07691, 11.08956, 11.10222, 11.11487, 11.12753,
11.14018,
    11.15284, 11.16549, 11.17815, 11.1908, 11.20346, 11.21611, 11.22876,
    11.24142, 11.25407, 11.26672, 11.27938, 11.29203, 11.30468,
11.31734,
    11.32999, 11.34264, 11.35529, 11.36795, 11.3806, 11.39325,
  10.88735, 10.90001, 10.91267, 10.92533, 10.93799, 10.95065, 10.9633,
    10.97596, 10.98862, 11.00128, 11.01394, 11.0266, 11.03926, 11.05192,
    11.06457, 11.07723, 11.08989, 11.10255, 11.1152, 11.12786, 11.14052,
    11.15317, 11.16583, 11.17849, 11.19114, 11.2038, 11.21646, 11.22911,
    11.24177, 11.25442, 11.26708, 11.27973, 11.29239, 11.30504, 11.3177,
    11.33035, 11.34301, 11.35566, 11.36832, 11.38097, 11.39362,
  10.88764, 10.9003, 10.91297, 10.92563, 10.93829, 10.95095, 10.96361,
    10.97627, 10.98893, 11.00159, 11.01425, 11.02691, 11.03957,
11.05223,
    11.06489, 11.07755, 11.09021, 11.10287, 11.11553, 11.12819,
11.14085,
    11.15351, 11.16617, 11.17883, 11.19149, 11.20414, 11.2168, 11.22946,
    11.24212, 11.25478, 11.26743, 11.28009, 11.29275, 11.3054, 11.31806,
    11.33072, 11.34337, 11.35603, 11.36869, 11.38134, 11.394,
  10.88794, 10.9006, 10.91327, 10.92593, 10.93859, 10.95125, 10.96392,
    10.97658, 10.98924, 11.00191, 11.01457, 11.02723, 11.03989,
11.05256,
    11.06522, 11.07788, 11.09054, 11.1032, 11.11586, 11.12852, 11.14119,
    11.15385, 11.16651, 11.17917, 11.19183, 11.20449, 11.21715,
11.22981,
    11.24247, 11.25513, 11.26779, 11.28045, 11.2931, 11.30576, 11.31842,
    11.33108, 11.34374, 11.3564, 11.36905, 11.38171, 11.39437,
  10.88823, 10.9009, 10.91356, 10.92623, 10.93889, 10.95156, 10.96422,
    10.97689, 10.98955, 11.00222, 11.01488, 11.02755, 11.04021,
11.05288,
    11.06554, 11.0782, 11.09087, 11.10353, 11.11619, 11.12886, 11.14152,
    11.15418, 11.16685, 11.17951, 11.19217, 11.20483, 11.21749,
11.23016,
    11.24282, 11.25548, 11.26814, 11.2808, 11.29346, 11.30612, 11.31878,
    11.33144, 11.3441, 11.35676, 11.36942, 11.38208, 11.39474,
  10.88853, 10.90119, 10.91386, 10.92653, 10.9392, 10.95186, 10.96453,
    10.9772, 10.98987, 11.00253, 11.0152, 11.02786, 11.04053, 11.0532,
    11.06586, 11.07853, 11.09119, 11.10386, 11.11652, 11.12919,
11.14185,
    11.15452, 11.16718, 11.17985, 11.19251, 11.20518, 11.21784, 11.2305,
    11.24317, 11.25583, 11.26849, 11.28116, 11.29382, 11.30648,
11.31915,
    11.33181, 11.34447, 11.35713, 11.36979, 11.38246, 11.39512,
  10.88882, 10.90149, 10.91416, 10.92683, 10.9395, 10.95217, 10.96484,
    10.97751, 10.99018, 11.00284, 11.01551, 11.02818, 11.04085,
11.05352,
    11.06618, 11.07885, 11.09152, 11.10419, 11.11685, 11.12952,
11.14219,
    11.15486, 11.16752, 11.18019, 11.19285, 11.20552, 11.21819,
11.23085,
    11.24352, 11.25618, 11.26885, 11.28151, 11.29418, 11.30684,
11.31951,
    11.33217, 11.34484, 11.3575, 11.37016, 11.38283, 11.39549,
  10.88912, 10.90179, 10.91446, 10.92713, 10.9398, 10.95247, 10.96515,
    10.97782, 10.99049, 11.00316, 11.01583, 11.0285, 11.04117, 11.05384,
    11.06651, 11.07918, 11.09185, 11.10452, 11.11719, 11.12986,
11.14252,
    11.15519, 11.16786, 11.18053, 11.1932, 11.20587, 11.21853, 11.2312,
    11.24387, 11.25654, 11.2692, 11.28187, 11.29454, 11.3072, 11.31987,
    11.33254, 11.3452, 11.35787, 11.37053, 11.3832, 11.39587,
    10.97813, 10.9908, 11.00347, 11.01614, 11.02882, 11.04149, 11.05416,
    11.06683, 11.0795, 11.09217, 11.10485, 11.11752, 11.13019, 11.14286,
    11.15553, 11.1682, 11.18087, 11.19354, 11.20621, 11.21888, 11.23155,
    11.24422, 11.25689, 11.26956, 11.28223, 11.2949, 11.30756, 11.32023,
    11.3329, 11.34557, 11.35824, 11.37091, 11.38357, 11.39624 ;
lat =
  44.60887, 44.60866, 44.60845, 44.60824, 44.60803, 44.60781, 44.6076,
    44.60738, 44.60717, 44.60695, 44.60672, 44.6065, 44.60628, 44.60606,
    44.60583, 44.6056, 44.60537, 44.60514, 44.60491, 44.60468, 44.60445,
    44.60421, 44.60397, 44.60373, 44.6035, 44.60325, 44.60301, 44.60277,
    44.60252, 44.60228, 44.60203, 44.60178, 44.60153, 44.60128,
44.60102,
    44.60077, 44.60051, 44.60025, 44.59999, 44.59973, 44.59947,
  44.61786, 44.61766, 44.61745, 44.61724, 44.61702, 44.61681, 44.6166,
    44.61638, 44.61616, 44.61594, 44.61572, 44.6155, 44.61528, 44.61505,
    44.61483, 44.6146, 44.61437, 44.61414, 44.61391, 44.61368, 44.61344,
    44.6132, 44.61297, 44.61273, 44.61249, 44.61225, 44.61201, 44.61176,
    44.61152, 44.61127, 44.61102, 44.61077, 44.61052, 44.61027,
44.61002,
    44.60976, 44.6095, 44.60925, 44.60899, 44.60873, 44.60846,
  44.62686, 44.62666, 44.62645, 44.62623, 44.62602, 44.62581, 44.6256,
    44.62538, 44.62516, 44.62494, 44.62472, 44.6245, 44.62428, 44.62405,
    44.62383, 44.6236, 44.62337, 44.62314, 44.62291, 44.62267, 44.62244,
    44.6222, 44.62197, 44.62173, 44.62149, 44.62125, 44.621, 44.62076,
    44.62051, 44.62027, 44.62002, 44.61977, 44.61952, 44.61927,
44.61901,
    44.61876, 44.6185, 44.61824, 44.61798, 44.61772, 44.61746,
  44.63586, 44.63565, 44.63544, 44.63523, 44.63502, 44.63481, 44.63459,
    44.63437, 44.63416, 44.63394, 44.63372, 44.6335, 44.63327, 44.63305,
    44.63282, 44.6326, 44.63237, 44.63213, 44.6319, 44.63167, 44.63144,
    44.6312, 44.63096, 44.63072, 44.63048, 44.63024, 44.63, 44.62975,
    44.62951, 44.62926, 44.62901, 44.62877, 44.62851, 44.62826,
44.62801,
    44.62775, 44.62749, 44.62724, 44.62698, 44.62672, 44.62645,
  44.64486, 44.64465, 44.64444, 44.64423, 44.64402, 44.6438, 44.64359,
    44.64337, 44.64315, 44.64293, 44.64272, 44.64249, 44.64227,
44.64204,
    44.64182, 44.64159, 44.64136, 44.64113, 44.6409, 44.64067, 44.64043,
    44.64019, 44.63996, 44.63972, 44.63948, 44.63924, 44.639, 44.63875,
    44.6385, 44.63826, 44.63801, 44.63776, 44.63751, 44.63726, 44.637,
    44.63675, 44.63649, 44.63623, 44.63597, 44.63571, 44.63545,
  44.65385, 44.65365, 44.65344, 44.65322, 44.65302, 44.6528, 44.65258,
    44.65237, 44.65215, 44.65193, 44.65171, 44.65149, 44.65126,
44.65104,
    44.65081, 44.65059, 44.65036, 44.65013, 44.64989, 44.64966,
44.64943,
    44.64919, 44.64895, 44.64872, 44.64848, 44.64824, 44.64799,
44.64775,
    44.6475, 44.64725, 44.64701, 44.64676, 44.6465, 44.64625, 44.646,
    44.64574, 44.64548, 44.64523, 44.64497, 44.64471, 44.64444,
  44.66285, 44.66264, 44.66243, 44.66222, 44.66201, 44.6618, 44.66158,
    44.66137, 44.66115, 44.66093, 44.66071, 44.66048, 44.66026,
44.66004,
    44.65981, 44.65958, 44.65936, 44.65912, 44.65889, 44.65866,
44.65842,
    44.65819, 44.65795, 44.65771, 44.65747, 44.65723, 44.65699,
44.65674,
    44.6565, 44.65625, 44.656, 44.65575, 44.6555, 44.65525, 44.65499,
    44.65474, 44.65448, 44.65422, 44.65396, 44.6537, 44.65344,
  44.67185, 44.67164, 44.67143, 44.67122, 44.67101, 44.6708, 44.67058,
    44.67036, 44.67015, 44.66993, 44.6697, 44.66948, 44.66926, 44.66903,
    44.66881, 44.66858, 44.66835, 44.66812, 44.66789, 44.66766,
44.66742,
    44.66718, 44.66695, 44.66671, 44.66647, 44.66623, 44.66598,
44.66574,
    44.66549, 44.66525, 44.665, 44.66475, 44.66449, 44.66424, 44.66399,
    44.66373, 44.66348, 44.66322, 44.66296, 44.6627, 44.66243,
  44.68085, 44.68064, 44.68043, 44.68022, 44.68001, 44.67979, 44.67958,
    44.67936, 44.67914, 44.67892, 44.6787, 44.67848, 44.67826, 44.67803,
    44.6778, 44.67758, 44.67735, 44.67712, 44.67688, 44.67665, 44.67642,
    44.67618, 44.67594, 44.6757, 44.67546, 44.67522, 44.67498, 44.67473,
    44.67449, 44.67424, 44.67399, 44.67374, 44.67349, 44.67324,
44.67299,
    44.67273, 44.67247, 44.67221, 44.67195, 44.67169, 44.67143,
  44.68985, 44.68964, 44.68943, 44.68922, 44.689, 44.68879, 44.68858,
    44.68836, 44.68814, 44.68792, 44.6877, 44.68748, 44.68725, 44.68703,
    44.6868, 44.68657, 44.68634, 44.68611, 44.68588, 44.68565, 44.68541,
    44.68518, 44.68494, 44.6847, 44.68446, 44.68422, 44.68398, 44.68373,
    44.68348, 44.68324, 44.68299, 44.68274, 44.68249, 44.68223,
44.68198,
    44.68172, 44.68147, 44.68121, 44.68095, 44.68069, 44.68042,
  44.69884, 44.69864, 44.69843, 44.69822, 44.698, 44.69779, 44.69757,
    44.69735, 44.69714, 44.69692, 44.6967, 44.69647, 44.69625, 44.69603,
    44.6958, 44.69557, 44.69534, 44.69511, 44.69488, 44.69464, 44.69441,
    44.69417, 44.69394, 44.6937, 44.69345, 44.69321, 44.69297, 44.69273,
    44.69248, 44.69223, 44.69198, 44.69173, 44.69148, 44.69123,
44.69098,
    44.69072, 44.69046, 44.6902, 44.68994, 44.68968, 44.68942,
  44.70784, 44.70763, 44.70742, 44.70721, 44.707, 44.70678, 44.70657,
    44.70635, 44.70613, 44.70591, 44.70569, 44.70547, 44.70525,
44.70502,
    44.7048, 44.70457, 44.70434, 44.70411, 44.70387, 44.70364, 44.7034,
    44.70317, 44.70293, 44.70269, 44.70245, 44.70221, 44.70197,
44.70172,
    44.70147, 44.70123, 44.70098, 44.70073, 44.70048, 44.70022,
44.69997,
    44.69971, 44.69946, 44.6992, 44.69894, 44.69868, 44.69841,
  44.71684, 44.71663, 44.71642, 44.71621, 44.716, 44.71578, 44.71556,
    44.71535, 44.71513, 44.71491, 44.71469, 44.71447, 44.71424,
44.71402,
    44.71379, 44.71356, 44.71333, 44.7131, 44.71287, 44.71264, 44.7124,
    44.71217, 44.71193, 44.71169, 44.71145, 44.7112, 44.71096, 44.71072,
    44.71047, 44.71022, 44.70997, 44.70972, 44.70947, 44.70922,
44.70897,
    44.70871, 44.70845, 44.70819, 44.70793, 44.70767, 44.70741,
  44.72584, 44.72563, 44.72542, 44.7252, 44.72499, 44.72478, 44.72456,
    44.72435, 44.72413, 44.72391, 44.72369, 44.72346, 44.72324,
44.72301,
    44.72279, 44.72256, 44.72233, 44.7221, 44.72187, 44.72163, 44.7214,
    44.72116, 44.72092, 44.72068, 44.72044, 44.7202, 44.71996, 44.71971,
    44.71947, 44.71922, 44.71897, 44.71872, 44.71847, 44.71821,
44.71796,
    44.7177, 44.71745, 44.71719, 44.71693, 44.71666, 44.7164,
  44.73483, 44.73463, 44.73441, 44.7342, 44.73399, 44.73378, 44.73356,
    44.73335, 44.73312, 44.73291, 44.73269, 44.73246, 44.73223,
44.73201,
    44.73178, 44.73156, 44.73133, 44.73109, 44.73086, 44.73063,
44.73039,
    44.73016, 44.72992, 44.72968, 44.72944, 44.7292, 44.72895, 44.72871,
    44.72846, 44.72821, 44.72797, 44.72771, 44.72746, 44.72721,
44.72696,
    44.7267, 44.72644, 44.72618, 44.72592, 44.72566, 44.7254,
  44.74383, 44.74362, 44.74341, 44.7432, 44.74299, 44.74277, 44.74256,
    44.74234, 44.74212, 44.7419, 44.74168, 44.74146, 44.74123, 44.74101,
    44.74078, 44.74055, 44.74032, 44.74009, 44.73986, 44.73962,
44.73939,
    44.73915, 44.73891, 44.73867, 44.73843, 44.73819, 44.73795,
44.73771,
    44.73746, 44.73721, 44.73696, 44.73671, 44.73646, 44.7362, 44.73595,
    44.73569, 44.73544, 44.73518, 44.73492, 44.73465, 44.73439,
  44.75283, 44.75262, 44.75241, 44.7522, 44.75198, 44.75177, 44.75156,
    44.75134, 44.75112, 44.7509, 44.75068, 44.75045, 44.75023, 44.75,
    44.74978, 44.74955, 44.74932, 44.74909, 44.74886, 44.74862,
44.74839,
    44.74815, 44.74791, 44.74767, 44.74743, 44.74719, 44.74694, 44.7467,
    44.74645, 44.7462, 44.74596, 44.7457, 44.74545, 44.7452, 44.74495,
    44.74469, 44.74443, 44.74417, 44.74391, 44.74365, 44.74339,
  44.76183, 44.76162, 44.76141, 44.7612, 44.76098, 44.76077, 44.76055,
    44.76033, 44.76012, 44.7599, 44.75967, 44.75945, 44.75923, 44.759,
    44.75877, 44.75854, 44.75832, 44.75808, 44.75785, 44.75762,
44.75738,
    44.75714, 44.75691, 44.75667, 44.75643, 44.75618, 44.75594, 44.7557,
    44.75545, 44.7552, 44.75495, 44.7547, 44.75445, 44.7542, 44.75394,
    44.75368, 44.75343, 44.75317, 44.75291, 44.75264, 44.75238,
  44.77082, 44.77061, 44.7704, 44.77019, 44.76998, 44.76976, 44.76955,
    44.76933, 44.76911, 44.76889, 44.76867, 44.76845, 44.76822, 44.768,
    44.76777, 44.76754, 44.76731, 44.76708, 44.76685, 44.76661,
44.76638,
    44.76614, 44.7659, 44.76566, 44.76542, 44.76518, 44.76493, 44.76469,
    44.76444, 44.76419, 44.76395, 44.76369, 44.76344, 44.76319,
44.76294,
    44.76268, 44.76242, 44.76216, 44.7619, 44.76164, 44.76138,
  44.77982, 44.77961, 44.7794, 44.77919, 44.77898, 44.77876, 44.77855,
    44.77833, 44.77811, 44.77789, 44.77767, 44.77744, 44.77722,
44.77699,
    44.77677, 44.77654, 44.77631, 44.77608, 44.77584, 44.77561,
44.77538,
    44.77514, 44.7749, 44.77466, 44.77442, 44.77417, 44.77393, 44.77369,
    44.77344, 44.77319, 44.77294, 44.77269, 44.77244, 44.77219,
44.77193,
    44.77167, 44.77142, 44.77116, 44.77089, 44.77063, 44.77037,
  44.78882, 44.78861, 44.7884, 44.78819, 44.78798, 44.78776, 44.78754,
    44.78733, 44.78711, 44.78689, 44.78666, 44.78644, 44.78622,
44.78599,
    44.78576, 44.78553, 44.78531, 44.78507, 44.78484, 44.78461,
44.78437,
    44.78413, 44.78389, 44.78366, 44.78341, 44.78317, 44.78293,
44.78268,
    44.78244, 44.78219, 44.78194, 44.78168, 44.78143, 44.78118,
44.78093,
    44.78067, 44.78041, 44.78015, 44.77989, 44.77963, 44.77937,
  44.79782, 44.79761, 44.7974, 44.79718, 44.79697, 44.79676, 44.79654,
    44.79632, 44.7961, 44.79588, 44.79566, 44.79544, 44.79521, 44.79499,
    44.79476, 44.79453, 44.7943, 44.79407, 44.79384, 44.7936, 44.79337,
    44.79313, 44.79289, 44.79265, 44.79241, 44.79217, 44.79192,
44.79168,
    44.79143, 44.79118, 44.79093, 44.79068, 44.79043, 44.79018,
44.78992,
    44.78966, 44.78941, 44.78915, 44.78888, 44.78862, 44.78836,
  44.80681, 44.80661, 44.80639, 44.80618, 44.80597, 44.80575, 44.80554,
    44.80532, 44.8051, 44.80488, 44.80466, 44.80444, 44.80421, 44.80399,
    44.80376, 44.80353, 44.8033, 44.80307, 44.80283, 44.8026, 44.80236,
    44.80212, 44.80189, 44.80165, 44.80141, 44.80116, 44.80092,
44.80067,
    44.80043, 44.80018, 44.79993, 44.79967, 44.79942, 44.79917,
44.79892,
    44.79866, 44.7984, 44.79814, 44.79788, 44.79762, 44.79735,
  44.81581, 44.8156, 44.81539, 44.81518, 44.81496, 44.81475, 44.81453,
    44.81432, 44.8141, 44.81388, 44.81366, 44.81343, 44.81321, 44.81298,
    44.81275, 44.81252, 44.81229, 44.81206, 44.81183, 44.8116, 44.81136,
    44.81112, 44.81088, 44.81064, 44.8104, 44.81016, 44.80991, 44.80967,
    44.80942, 44.80917, 44.80892, 44.80867, 44.80842, 44.80817,
44.80791,
    44.80765, 44.8074, 44.80713, 44.80687, 44.80661, 44.80635,
  44.82481, 44.8246, 44.82439, 44.82418, 44.82396, 44.82375, 44.82353,
    44.82331, 44.82309, 44.82287, 44.82265, 44.82243, 44.8222, 44.82198,
    44.82175, 44.82152, 44.82129, 44.82106, 44.82082, 44.82059,
44.82035,
    44.82012, 44.81988, 44.81964, 44.8194, 44.81915, 44.81891, 44.81866,
    44.81842, 44.81817, 44.81792, 44.81767, 44.81741, 44.81716,
44.81691,
    44.81665, 44.81639, 44.81613, 44.81587, 44.81561, 44.81534,
  44.83381, 44.8336, 44.83339, 44.83317, 44.83296, 44.83274, 44.83253,
    44.83231, 44.83209, 44.83187, 44.83165, 44.83142, 44.8312, 44.83097,
    44.83075, 44.83052, 44.83029, 44.83006, 44.82982, 44.82959,
44.82935,
    44.82911, 44.82887, 44.82863, 44.82839, 44.82815, 44.8279, 44.82766,
    44.82741, 44.82716, 44.82691, 44.82666, 44.82641, 44.82616, 44.8259,
    44.82564, 44.82538, 44.82512, 44.82486, 44.8246, 44.82434,
  44.8428, 44.84259, 44.84238, 44.84217, 44.84196, 44.84174, 44.84153,
    44.84131, 44.84109, 44.84087, 44.84064, 44.84042, 44.8402, 44.83997,
    44.83974, 44.83951, 44.83928, 44.83905, 44.83882, 44.83858,
44.83835,
    44.83811, 44.83787, 44.83763, 44.83739, 44.83715, 44.8369, 44.83665,
    44.83641, 44.83616, 44.83591, 44.83566, 44.8354, 44.83515, 44.83489,
    44.83464, 44.83438, 44.83412, 44.83386, 44.8336, 44.83333,
  44.8518, 44.85159, 44.85138, 44.85117, 44.85095, 44.85074, 44.85052,
    44.8503, 44.85009, 44.84986, 44.84964, 44.84942, 44.84919, 44.84897,
    44.84874, 44.84851, 44.84828, 44.84805, 44.84781, 44.84758,
44.84734,
    44.84711, 44.84687, 44.84663, 44.84638, 44.84614, 44.8459, 44.84565,
    44.8454, 44.84515, 44.8449, 44.84465, 44.8444, 44.84415, 44.84389,
    44.84363, 44.84337, 44.84311, 44.84285, 44.84259, 44.84232,
  44.8608, 44.86059, 44.86038, 44.86016, 44.85995, 44.85974, 44.85952,
    44.8593, 44.85908, 44.85886, 44.85864, 44.85841, 44.85819, 44.85796,
    44.85773, 44.85751, 44.85728, 44.85704, 44.85681, 44.85658,
44.85634,
    44.8561, 44.85586, 44.85562, 44.85538, 44.85514, 44.85489, 44.85464,
    44.8544, 44.85415, 44.8539, 44.85365, 44.85339, 44.85314, 44.85288,
    44.85263, 44.85237, 44.85211, 44.85184, 44.85159, 44.85132,
  44.8698, 44.86959, 44.86937, 44.86916, 44.86895, 44.86873, 44.86852,
    44.8683, 44.86808, 44.86786, 44.86763, 44.86741, 44.86719, 44.86696,
    44.86673, 44.8665, 44.86627, 44.86604, 44.86581, 44.86557, 44.86533,
    44.8651, 44.86486, 44.86462, 44.86438, 44.86413, 44.86389, 44.86364,
    44.86339, 44.86314, 44.8629, 44.86264, 44.86239, 44.86213, 44.86188,
    44.86162, 44.86136, 44.8611, 44.86084, 44.86058, 44.86031,
  44.87879, 44.87858, 44.87837, 44.87816, 44.87794, 44.87773, 44.87751,
    44.8773, 44.87708, 44.87685, 44.87663, 44.87641, 44.87618, 44.87596,
    44.87573, 44.8755, 44.87527, 44.87503, 44.8748, 44.87457, 44.87433,
    44.87409, 44.87385, 44.87361, 44.87337, 44.87313, 44.87288,
44.87263,
    44.87239, 44.87214, 44.87189, 44.87164, 44.87138, 44.87113,
44.87087,
    44.87062, 44.87036, 44.8701, 44.86983, 44.86957, 44.86931,
  44.88779, 44.88758, 44.88737, 44.88716, 44.88694, 44.88673, 44.88651,
    44.88629, 44.88607, 44.88585, 44.88563, 44.8854, 44.88518, 44.88495,
    44.88472, 44.88449, 44.88427, 44.88403, 44.8838, 44.88356, 44.88333,
    44.88309, 44.88285, 44.88261, 44.88237, 44.88212, 44.88188,
44.88163,
    44.88139, 44.88113, 44.88089, 44.88063, 44.88038, 44.88012,
44.87987,
    44.87961, 44.87935, 44.87909, 44.87883, 44.87857, 44.8783,
  44.89679, 44.89658, 44.89637, 44.89615, 44.89594, 44.89573, 44.89551,
    44.89529, 44.89507, 44.89485, 44.89463, 44.8944, 44.89418, 44.89395,
    44.89372, 44.89349, 44.89326, 44.89303, 44.8928, 44.89256, 44.89232,
    44.89209, 44.89185, 44.89161, 44.89136, 44.89112, 44.89087,
44.89063,
    44.89038, 44.89013, 44.88988, 44.88963, 44.88937, 44.88912,
44.88886,
    44.88861, 44.88835, 44.88809, 44.88783, 44.88756, 44.8873,
  44.90578, 44.90557, 44.90536, 44.90515, 44.90494, 44.90472, 44.9045,
    44.90429, 44.90406, 44.90384, 44.90362, 44.9034, 44.90317, 44.90295,
    44.90272, 44.90249, 44.90226, 44.90202, 44.90179, 44.90155,
44.90132,
    44.90108, 44.90084, 44.9006, 44.90036, 44.90011, 44.89987, 44.89962,
    44.89938, 44.89912, 44.89888, 44.89862, 44.89837, 44.89811,
44.89786,
    44.8976, 44.89734, 44.89708, 44.89682, 44.89656, 44.89629,
  44.91478, 44.91457, 44.91436, 44.91415, 44.91393, 44.91372, 44.9135,
    44.91328, 44.91306, 44.91284, 44.91262, 44.9124, 44.91217, 44.91194,
    44.91171, 44.91148, 44.91125, 44.91102, 44.91079, 44.91055,
44.91031,
    44.91008, 44.90984, 44.9096, 44.90935, 44.90911, 44.90886, 44.90862,
    44.90837, 44.90812, 44.90787, 44.90762, 44.90736, 44.90711,
44.90685,
    44.90659, 44.90634, 44.90607, 44.90582, 44.90555, 44.90528,
  44.92378, 44.92357, 44.92336, 44.92315, 44.92293, 44.92271, 44.9225,
    44.92228, 44.92206, 44.92184, 44.92162, 44.92139, 44.92117,
44.92094,
    44.92071, 44.92048, 44.92025, 44.92002, 44.91978, 44.91955,
44.91931,
    44.91907, 44.91883, 44.91859, 44.91835, 44.91811, 44.91786,
44.91761,
    44.91737, 44.91711, 44.91687, 44.91661, 44.91636, 44.9161, 44.91585,
    44.91559, 44.91533, 44.91507, 44.91481, 44.91454, 44.91428,
  44.93278, 44.93257, 44.93235, 44.93214, 44.93193, 44.93171, 44.9315,
    44.93127, 44.93106, 44.93084, 44.93061, 44.93039, 44.93016,
44.92994,
    44.92971, 44.92948, 44.92924, 44.92901, 44.92878, 44.92854,
44.92831,
    44.92807, 44.92783, 44.92759, 44.92735, 44.9271, 44.92686, 44.92661,
    44.92636, 44.92611, 44.92586, 44.92561, 44.92535, 44.9251, 44.92484,
    44.92458, 44.92432, 44.92406, 44.9238, 44.92354, 44.92327,
  44.94177, 44.94156, 44.94135, 44.94114, 44.94093, 44.94071, 44.94049,
    44.94027, 44.94005, 44.93983, 44.93961, 44.93938, 44.93916,
44.93893,
    44.9387, 44.93847, 44.93824, 44.93801, 44.93777, 44.93754, 44.9373,
    44.93707, 44.93682, 44.93658, 44.93634, 44.9361, 44.93585, 44.9356,
    44.93536, 44.9351, 44.93486, 44.9346, 44.93435, 44.93409, 44.93384,
    44.93358, 44.93332, 44.93306, 44.9328, 44.93253, 44.93227,
  44.95077, 44.95056, 44.95035, 44.95013, 44.94992, 44.9497, 44.94949,
    44.94927, 44.94905, 44.94883, 44.9486, 44.94838, 44.94815, 44.94793,
    44.9477, 44.94747, 44.94724, 44.947, 44.94677, 44.94653, 44.9463,
    44.94606, 44.94582, 44.94558, 44.94534, 44.94509, 44.94485, 44.9446,
    44.94435, 44.9441, 44.94385, 44.9436, 44.94334, 44.94309, 44.94283,
    44.94257, 44.94231, 44.94205, 44.94179, 44.94153, 44.94126,
  44.95977, 44.95956, 44.95935, 44.95913, 44.95892, 44.9587, 44.95848,
    44.95827, 44.95805, 44.95782, 44.9576, 44.95737, 44.95715, 44.95692,
    44.9567, 44.95646, 44.95623, 44.956, 44.95576, 44.95553, 44.95529,
    44.95506, 44.95481, 44.95457, 44.95433, 44.95409, 44.95384,
44.95359,
    44.95335, 44.95309, 44.95285, 44.95259, 44.95234, 44.95208,
44.95183,
    44.95157, 44.95131, 44.95105, 44.95079, 44.95052, 44.95026,
  44.96877, 44.96856, 44.96834, 44.96813, 44.96791, 44.9677, 44.96748,
    44.96726, 44.96704, 44.96682, 44.9666, 44.96637, 44.96615, 44.96592,
    44.96569, 44.96546, 44.96523, 44.965, 44.96476, 44.96453, 44.96429,
    44.96405, 44.96381, 44.96357, 44.96333, 44.96308, 44.96284,
44.96259,
    44.96234, 44.96209, 44.96184, 44.96159, 44.96133, 44.96108,
44.96082,
    44.96056, 44.9603, 44.96004, 44.95978, 44.95951, 44.95925 ;
time = 0 ;
idl = "" ;
geo_limits = 4941000, 649000, 4981000, 689000 ;
grid_mesh = 1000, 1000 ;
cum_pr_mm =
  0, 0, 0, 0, 0, 0, 0, 0.01338021, 0.01602855, 0.01399816, 0.01278954,
    0.01338021, 0.01168529, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
  0, 0, 0, 0, 0, 0.03300805, 0.01360867, 0.02896279, 0.01920108,
0.01399816,
    0.01338021, 0.01338021, 0.01168529, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
  0, 0, 0, 0, 0.03300805, 0.04736773, 0.0609764, 0.04973597, 0.03567044,
    0.01116944, 0.01168529, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
  0.02455989, 0.04993062, 0.03596432, 0.01866684, 0.0505513, 0.06572119,
    0.0528961, 0.03369653, 0.01116944, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
  0.1097616, 0.06299267, 0.04266773, 0.02755423, 0.02300154, 0.0424173,
    0.0528961, 0.02008785, 0.01116944, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
  0.1304922, 0.09385033, 0.07922021, 0.03308987, 0.02300154, 0.01835346,
    0.0528961, 0.01464464, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
  0.1804126, 0.1297998, 0.08104637, 0.05398374, 0.02300154, 0.01168529,
    0.01602855, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
  0.1884816, 0.1279853, 0.1095784, 0.04651736, 0, 0, 0.01602855, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
    0, 0, 0, 0, 0, 0,
  0.1374868, 0.09564797, 0.08922645, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
0, 0,
  0.07957859, 0.04417009, 0.006519975, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0, 0,
  0.06058752, 0.04417009, 0.04417009, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0, 0,
  0.07302121, 0.04148318, 0.02822841, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0, 0,
  0.05175512, 0.07778501, 0.01630224, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0.008171189,
    0, 0, 0, 0,
  0.03982895, 0.06308942, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.008171189,
    0.007810473, 0, 0, 0,
  0.03421111, 0.02101557, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.007810473,
0,
0, 0,
  0.03421111, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
  0.01464464, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
0.01222496,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.006232153, 0, 0.006232153,
    0.006232153, 0, 0, 0, 0.006232153,
    0.01222496, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.006232153, 0.03465264,
    0.03465264, 0, 0, 0.008548561, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0.01024057, 0.04753254, 0.01342676, 0,
    0.008548561, 0.008548561, 0,
0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.01024057, 0, 0, 0, 0, 0,
0, 0,
  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.005694066, 0.02015775, 0, 0, 0, 0, 0,
0, 0,
  0, 0, 0, 0, 0, 0, 0, 0, 0.01172595, 0.01172595, 0, 0.02015775, 0, 0,
0, 0,
0, 0,
  0, 0, 0, 0, 0, 0, 0, 0, 0.01404686, 0.01404686, 0, 0.02015775,
0.008548561,
0,
    0, 0, 0, 0,
  0, 0, 0, 0, 0, 0, 0, 0.005442702, 0.01404686, 0.01172595, 0,
0.008548561,
0,
    0, 0, 0, 0, 0,
  0, 0, 0, 0, 0, 0, 0, 0, 0, 0.01172595, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
0, 0,
0, 0,
0, 0,
    0, 0, 0, 0, 0, 0.01676881, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0,
    0, 0, 0, 0, 0, 0.009754568, 0.03208978, 0.02744518, 0, 0, 0, 0, 0,
0, 0,
    0.004762364,
0, 0,
    0, 0.02633787, 0.02101557, 0.01338021, 0.01338021, 0, 0, 0.122796,
0,
    0.02633787, 0, 0.2787667, 0, 0, 0.06662081, 0.05425636 ;
Enrico Gabrielli
Album fotografico di bonushenricus: http://www.flickr.com/photos/10688869@N03/show/
Linux count registered user #518831 - Gnu/Linux Debian 6.0
