[gdal-dev] [gdal-java-1.8.0]TransformPoint() - different values for same inputs, why?
mett mettbest at gmail.com
Wed Jul 6 15:43:42 EDT 2011
Hello everybody,
I'm using GDAL 1.8.0 with Java, and I do not why but I got different results
with TransformPoint with same inputs. Maybe I'm wrong, anyway see this:
Upper Left = (/258321.25943477/, 655225.28062628)
Abs: *-24.39163021771631*, 66.2996405709653
Lower Left = (/258321.25943477/, 574605.28062628)
Abs: *-24.24282066963955*, 65.5792295908428
Upper Right = (/339151.25943477,/ 655225.28062628)
Abs: *-22.593238696114604*, 66.35110363848813
Lower Right = (/339151.25943477,/ 574605.28062628)
Abs: *-22.493807890469444*, 65.62928831950212
Those are the corners of my image, and as you can see when I try to convert
with TransformPoint(X,Y), I got different value for example with static X
and variable X.
Thank you for your help,
Mattia
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-java-1-8-0-TransformPoint-different-values-for-same-inputs-why-tp6555787p6555787.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
