[gdal-dev] Re: Warping an image with both a geotransform and control points
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Jul 7 05:34:39 EDT 2011
Hi all,
This has come up before, but I'm still struggling for an answer. I want
to rubbersheet an already projected image with control points, so as to
remove small errors.On a suggestion by Frank
(http://lists.osgeo.org/pipermail/gdal-dev/2009-February/019775.html) I
produced a VRT file of the georeferenced image and added control points
to shift the image 1000m to the right. (see below). However,  GDALWARP
ignores the control points and returns the original georeferenced image.
When I remove the georeferencing information, it does use the control
points, but returns a raw image shifted to the right.
Is it possible to rubbersheet a georeferenced image with control points,
or am I chasing a red herring?
Thanks,
Jan
<VRTDataset rasterXSize="310" rasterYSize="343">
<SRS>PROJCS[&quot;Amersfoort / RD
New&quot;,GEOGCS[&quot;Amersfoort&quot;,DATUM[&quot;Amersfoort&quot;,SPHEROID[&quot;Bessel
1841&quot;,6377397.155,299.1528128000008,AUTHORITY[&quot;EPSG&quot;,&quot;7004&quot;]],AUTHORITY[&quot;EPSG&quot;,&quot;6289&quot;]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;degree&quot;,0.0174532925199433],AUTHORITY[&quot;EPSG&quot;,&quot;4289&quot;]],PROJECTION[&quot;Oblique_Stereographic&quot;],PARAMETER[&quot;latitude_of_origin&quot;,52.15616055555555],PARAMETER[&quot;central_meridian&quot;,5.38763888888889],PARAMETER[&quot;scale_factor&quot;,0.9999079],PARAMETER[&quot;false_easting&quot;,155000],PARAMETER[&quot;false_northing&quot;,463000],UNIT[&quot;metre&quot;,1,AUTHORITY[&quot;EPSG&quot;,&quot;9001&quot;]],AUTHORITY[&quot;EPSG&quot;,&quot;28992&quot;]]</SRS>
<GeoTransform> -8.5000000000000000e+03,  1.0000000000000000e+03,
0.0000000000000000e+00,  2.8750000000000000e+05,
0.0000000000000000e+00,  1.0000000000000000e+03</GeoTransform>
<Metadata />
<Metadata domain="IMAGE_STRUCTURE">
<MDI key="INTERLEAVE">BAND</MDI>
</Metadata>
<GCPList>
<GCP Id="" Pixel="0.0000" Line="0.0000" X="1.000000000000E+03"
Y="0.000000000000E+00" />
<GCP Id="" Pixel="1000.0000" Line="0.0000" X="2.000000000000E+03"
<GCP Id="" Pixel="1000.0000" Line="1000.0000" X="2.000000000000E+03"
Y="2.000000000000E+03" />
<GCP Id="" Pixel="0.0000" Line="1000.0000" X="1.000000000000E+03"
Y="1.000000000000E+03" />
</GCPList>
<VRTRasterBand dataType="Float64" band="1">
<Metadata />
<ColorInterp>Gray</ColorInterp>
<SimpleSource>
<SourceFilename relativeToVRT="1">test.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="310" RasterYSize="343" DataType="Float64"
BlockXSize="310" BlockYSize="3" />
<SrcRect xOff="0" yOff="0" xSize="310" ySize="343" />
<DstRect xOff="0" yOff="0" xSize="310" ySize="343" />
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110707/2792d47c/attachment.html
