[gdal-dev] joining shapefile to PG table
Even Rouault even.rouault at mines-paris.org
Thu Jul 7 16:17:41 EDT 2011
Le jeudi 07 juillet 2011 21:57:31, William Kyngesburye a écrit :
> I'm having a problem joining a Postgres table to a shapefile.  I've done
> this in the past with MySQL tables.
> ogrinfo -al -so myshapefile.shp -sql "SELECT * FROM myshapefile LEFT JOIN
> 'PG:dbname=mypgdb host=localhost user=someuser password='.mypgtable ON
> myshapefile.keyfield = mypgtable.keyfield" INFO: Open of `myshqpefile.shp'
>       using driver `ESRI Shapefile' successful.
> ERROR 1: SQL Expression Parsing Error: syntax error
William,
I've just tried something really close to the above and it works in trunk and
1.8.1.
I get a segfault in 1.8.0, but the segfault can only occur if SQL parsing is
successfull. So I don't understand why you get the SQL parsing error. I guess
you pasted a simplified/reworked version of your exact SQL, so maybe check it
once more...
As far as the segfault is concerned, this is an identified regression of 1.8.0
that has been addressed in to-be-soon-released-1.8.1 (see
http://trac.osgeo.org/gdal/ticket/4112)
Best regards,
Even
