[gdal-dev] joining shapefile to PG table
William Kyngesburye woklist at kyngchaos.com
Thu Jul 7 17:28:52 EDT 2011
On Jul 7, 2011, at 4:22 PM, Even Rouault wrote:
>> Only simplified the names.  The shapefile name starts with numbers (natural
>> earth shapefiles).  There's the problem.  I removed the leading numbers,
>> and simplified the shapefile names to a few letters (they're also long
>> names), no syntax error (segfault).  Renamed with a short name with a
>> single leading number, again the syntax error.
>> So, it's a SQL limitation on names?
> Yes, SQL identifiers cannot start by a number without being quoted (the SQL
> engine of previous versions was perhaps a bit more tolerant, but the newer
> behaviour is closer to the one of the SQL engines you find in DBs such as
> postgres, mysql, sqlite, etc...)
> I've managed to make the request work (*) by changing it like the following :
> ogrinfo 123.dbf  -sql "select * from '123' onetwothree left join
> 'PG:dbname=autotest port=5432'.poly on onetwothree.prfedea = poly.prfedea"
> 1) quote the layername after the FROM : '123'
> 2) just after, add an alias name for the layername : onetwothree
> 3) use the alias name in the ON because it won't like 123 or '123'
Ah, sweet, I don't have to rename all my shapefiles :)  The quoting and aliasing works.  Thanks.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
