[gdal-dev] GDAL for Python 3.2 on Windows 64bit
Tamas Szekeres szekerest at gmail.com
Sun Jul 10 10:18:01 EDT 2011
GDAL Python 3.2 packages has now been added to the builds at
http://www.gisinternals.com/sdk/
Best regards,
Tamas
2011/7/9 Isaac Gerg <isaac.gerg at gergltd.com>
> This sounds great.  Thanks so much Tamas.
> Isaac
> On Sat, Jul 9, 2011 at 5:07 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> I'm just working on to include that in the builds at
>> Unfortunately I always have to patch the python-distutils stuff from
>> versions to versions so as to make it work with all the supported
>> compilers...
>> Best regards,
>> Tamas
>>> Do you guys know when 3.2 will be supported?  How do I build from 3.2
>>> currently using the patches you mentioned -- are there instructions
>>> anywhere?
>>> Thanks in advance,
>>> Isaac
>>> On Sat, Jul 9, 2011 at 8:28 AM, Even Rouault <
>>> even.rouault at mines-paris.org> wrote:
>>>> Le samedi 09 juillet 2011 13:56:54, Tamas Szekeres a écrit :
>>>> > 2011/7/8 Even Rouault <even.rouault at mines-paris.org>
>>>> > > http://vbkto.dyndns.org/sdk/ proposes bindings for 2.6, 2.7 and
>>>> 3.1.
>>>> > > Perhaps
>>>> > > Tamas would want to add support for 3.2 ?
>>>> > How do we stand with the Python 3.2 support in GDAL? Do we still
>>>> require to
>>>> > patch the gererated interface files so as to compile the bindings
>>>> > successfully?
>>>> > I'm a bit hesitant to include a patching step as part of the build
>>>> > execution sequence.
>>>> I've just downloaded the latest swig version 2.0.4 and the good news is
>>>> that
>>>> it now generates binding files compatible with Python 3.2 (as well as
>>>> with
>>>> previous Python versions). I also tested quickly with Java and Perl and
>>>> the
>>>> generated files are good enough to enable "make test" to run
>>>> successfully.
>>>> However, with CSharp, the generated cpp files have the following
>>>> duplicate
>>>> declaration
>>>>  static OsrPINVOKE() {
>>>> which causes the following error :
>>>> mcs /debug:full /target:library /out:osr_csharp.dll osr/*.cs
>>>> AssemblyInfo.cs
>>>> osr/OsrPINVOKE.cs(192,10): error CS0111: A member
>>>> `OSGeo.OSR.OsrPINVOKE.OsrPINVOKE()' is already defined. Rename this
>>>> member or
>>>> use different parameter types
>>>> osr/OsrPINVOKE.cs(188,10): (Location of the symbol related to previous
>>>> error)
>>>> whereas it is ok with swig 1.3.40
>>>> I couldn't find a relevant ticket in their bug tracker about this
>>>> duplicate
>>>> PINVOKE.
>>>> > Best regards,
>>>> > Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110710/42ba546b/attachment.html
