[gdal-dev] Re: Change the spatial reference of a shapeile
Solimyr giannicristian at msn.com
Mon Jul 11 06:12:39 EDT 2011
Thx, I tried to copy the file .prj but didn't work so I moved to use the
ogr2ogr method using -a_srs but I'm not able to do that...
I get the spatialRef using ogrinfo, like:
GEOGCS["GCS_WGS_1984",
    DATUM["WGS_1984",
        SPHEROID["WGS_1984",637813.0,298.252223563]],
    PRIMEM["Greenwich",0.0],
    UNIT["Degree",0.0174532925199433]]
But I don't know how use it with the ogr2ogr utility. I think that I must
just use this spatialRef to the new shapefile but I don't know why I must
put the source and also the dst....I tried:
ogr2ogr -a_srs GEOGCS["GCS_WGS_1984",\n    DATUM["WGS_1984",\n
SPHEROID["WGS_1984",637813.0,298.252223563]],\n
PRIMEM["Greenwich",0.0],\n    UNIT["Degree",0.0174532925199433]] shape.shp
But doesn't work...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Change-the-spatial-reference-of-a-shapeile-tp6561998p6570374.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
