[gdal-dev] Re: Change the spatial reference of a shapeile
Solimyr giannicristian at msn.com
Mon Jul 11 11:01:31 EDT 2011
Sorry, I do not understand...You mean to write the spatialRef to a txt file
and then doing something like:
$ ogr2ogr  -a_srs spatialRef.txt  dst_shape.shp  src_shape.shp
Is this what you mean? Where inside the txt file there is:
GEOGCS["GCS_WGS_1984",
   DATUM["WGS_1984",
       SPHEROID["WGS_1984",637813.0,298.252223563]],
   PRIMEM["Greenwich",0.0],
   UNIT["Degree",0.0174532925199433]]
Is correct?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Change-the-spatial-reference-of-a-shapeile-tp6561998p6571241.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
