[gdal-dev] RE: How to get some special metadata of HDF5 Cosmo-Skymed file
Alex Mantaut alexmantaut at suremptec.com.ar
Mon Jul 11 11:19:05 EDT 2011
I'm not sure if I understood your problem... You can't find the
Calibration Constant?
In that case the calibration constant is a property of the Sxx group.
Check csk-product handbook page 45 for more information.
Hope it helps!
Regards
2011/7/11 RSyaoxin <RSyaoxin at hotmail.com>:
> Thanks Alex Mantaut .This document is what I previously reference.Maybe the
> problem is that I do not know how to extract "Calibration Constant"or"K"
> parameters.
> Kind Regards
> ________________________________
> Date: Mon, 11 Jul 2011 07:36:52 -0700
> From: [hidden email]
> To: [hidden email]
> Subject: RE: How to get some special metadata of HDF5 Cosmo-Skymed file
> To be honest I know nothing about radiation calibration... Did you
> checked out this document?
> http://www.e-geos.it/products/pdf/COSMO-SkyMed-Image_Calibration.pdf
> other relevant information can be found at:
> http://www.e-geos.it/products/cosmo.html
> Hope it helps!
> Regards
> 2011/7/11 RSyaoxin <[hidden email]>:
>> Thanks Antonio Valentino and Alex Mantaut. I've got these
>> parameters.I have
>> a new problem,I need to get the backscatter image,but the calibration
>> result
>> is not correct,the calibrated image pixels are all zero.I doubt that my
>> method is not correct.Who can give me some information about Cosmo-Skymed
>> radiation calibration?How should I do?
>> Best regards.
>> Date: Mon, 11 Jul 2011 06:55:54 -0700
>> To: [hidden email]
>> Subject: Re: How to get some special metadata of HDF5 Cosmo-Skymed file
>> Hi RSyaoxin,
>> Antonio is right, there was an issue on geting the root metadata from
>> hdf5 files and is has been fixed in trunk, you will need to recompile
>> gdal in order to get that information.
>> After you rebuilt the library, an example on getting the metadata:
>> #include "gdal_priv.h"
>> #include <iostream>
>> #include <cstdlib>
>> #include <string>
>> #include <stdexcept>
>> using namespace std;
>> int main(int argc, char **argv)
>> GDALDataset  *poDataset;
>>   GDALAllRegister();
>>   //Open the subdataset
>>   //The filename should be formated like this
>>   //HDF5:filepath://subdataset
>>   poDataset = (GDALDataset *) GDALOpen(
>> "HDF5:CSKS1_DGM_B_HR_00_HH_RA_SF_20080211191721_20080211191753.h5://S01/SBI",
>> GA_ReadOnly );
>>   if( poDataset == NULL )
>>       cout <<"error opening dataset"<<endl;
>>   else
>>            //To get the metadata the item name should be formated like
>> this:
>>            //Every space and group separator should be replaced with
>> an underscore (_)
>>            //I.e. You need item Beam ID from group S01:
>>            const char *pszBeamId =
>> poDataset->GetMetadataItem("S01_Beam_ID");
>>            cout <<  pszBeamId <<endl;
>>            //I.e. You need item Rescaling factor the root:
>>            const char *pszRescalingFactor =
>> poDataset->GetMetadataItem("Rescaling_Factor");
>>            cout <<  pszRescalingFactor <<endl;
>> Best regards
>> 2011/7/10 Antonio Valentino <[hidden email]>:
>>> Hi RSyaoxin,
>>> Il 10/07/2011 16:08, RSyaoxin ha scritto:
>>>> Hi,all.
>>>>       I want to calibrate the Cosmo-Skymed radar data, and I need some
>>>> parameters, such as "Calibration Constant","Rescaling Factor","Reference
>>>> Incidence Angle" and so on.However,I'm a beginner,I don't know how to
>>>> get
>>>> HDF5 metadata,Somebody can give me a tutorial in c or c++?
>>>>       Furthermore,I used HDFView to see the file's metadata and found
>>>> that
>>>> these information is stored in the metadata corresponding to the "root"
>>>> of
>>>> the file, I try to use gdalinfo to get the file's metadata  and can't
>>>> find
>>>> it.That's why?
>>>>       Subdatasets:
>>>> SUBDATASET_1_NAME=HDF5:"D:\CSKS3_GEC_B_WR_01_VV_RD_SF_20100720100133_20100720100148.h5"://MBI
>>>>   SUBDATASET_1_DESC=[9028x12156] //MBI (16-bit unsigned integer)
>>>> SUBDATASET_2_NAME=HDF5:"D:\CSKS3_GEC_B_WR_01_VV_RD_SF_20100720100133_20100720100148.h5"://QLK
>>>>   SUBDATASET_2_DESC=[902x1215] //QLK (8-bit unsigned character)
>>>> I hope to get some help.Thank you!
>>>> Kind regards.
>>> The HDF5 driver has been recently updated to improve metadata management:
>>> http://trac.osgeo.org/gdal/changeset/22517
>>> http://trac.osgeo.org/gdal/ticket/2412
>>> The problem you are experimenting should be fixed in trunk but you need
>>> to re-build GDAL from sources to get it.
>>> regards
>>> Antonio Valentino
>>> gdal-dev mailing list
>>> [hidden email]
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>      Alex Mantaut
>> SUR Emprendimientos Tecnológicos
>> Perú 345  Piso 5to Oficina "B" (C1067AAG)
>> Ciudad de Buenos Aires, Argentina
>> Tel. +54 (11) 4342-2976/84
>> [hidden email]
>> www.suremptec.com
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1803224.n2.nabble.com/How-to-get-some-special-metadata-of-HDF5-Cosmo-Skymed-file-tp6567852p6571000.html
>> To unsubscribe from How to get some special metadata of HDF5 Cosmo-Skymed
>> file, click here.
>> View this message in context: RE: How to get some special metadata of HDF5
>> Cosmo-Skymed file
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> [hidden email]
>      Alex Mantaut
> [hidden email]
> www.suremptec.com
> [hidden email]
> below:
> http://osgeo-org.1803224.n2.nabble.com/How-to-get-some-special-metadata-of-HDF5-Cosmo-Skymed-file-tp6567852p6571128.html
> file, click here.
> Cosmo-Skymed file
> gdal-dev at lists.osgeo.org
     Alex Mantaut
www.suremptec.com
