[gdal-dev] gdalnumeric problems with Python 3.2 Windows 7 64 bit
Isaac Gerg isaac.gerg at gergltd.com
Mon Jul 11 16:14:18 EDT 2011
Thank you!
On Mon, Jul 11, 2011 at 4:13 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Isaac,
> I've took a chance to install the numpy-amd64 packages from the site you
> mentioned. If the things are going well the tomorrow builds will contain the
> numpy enabled gdal win64 packages.
> I should however mention that I have some negative experiences with the
> numpy enabled GDAL (WIN64) packages since the GDAL python tests were
> crashing with this option, when I was trying to include this this last time.
> So in case if the tests are not working well, I must revert this addition
> and remove numpy from the Win64 setup. (The Win32 GDALpackages already
> contain numpy at http://www.gisinternals.com/sdk)
> Best regards,
> Tamas
> 2011/7/11 Isaac Gerg <isaac.gerg at gergltd.com>
>> Im not sure I understood your original message.  In any case, I have it
>> working now though I used a different GDAL build than the one down by Tamas.
>> I uninstalled Tamas' build (had to delete a few files in the site-packages
>> directory) and then install the GDAL libs from here:
>>  http://www.lfd.uci.edu/~gohlke/pythonlibs/
>> GDAL-1.8.1.win-amd64-py3.2.‌exe<http://www.lfd.uci.edu/%7Egohlke/pythonlibs/>
>>   [6.6 MB]  [Python 3.2]  [64 bit]  [Jul 08, 2011]
>> My code now works!
>> Isaac
>> On Mon, Jul 11, 2011 at 2:47 PM, Even Rouault <
>> even.rouault at mines-paris.org> wrote:
>>> Le lundi 11 juillet 2011 20:40:56, Isaac Gerg a écrit :
>>> > Hmmm.. I just downloaded numpy from here:
>>> > http://www.lfd.uci.edu/~gohlke/pythonlibs/ the 64bit windows one
>>> without
>>> > MKL.
>>> > I installed it successfully and then reran the code.  Same error.  Any
>>> > ideas?
>>> Yes, as I said in my previous answer, you need numpy at your side, but
>>> that's
>>> not enough. The GDAL python bindings need to be rebuilt against a python
>>> with
>>> numpy installed. So some extra work would be needed on Tamas side.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110711/20ca130b/attachment.html
