[gdal-dev] PDF via podofo
Joaquim Luis jluis at ualg.pt
Tue Jul 12 09:34:19 EDT 2011
Evan,
It seams to work now. I say "seams" because with podofo it also requires
to have available "pdftoppm"
gdal_translate lixo.pdf lixo.tiff
Input file size is 1239, 1754
0'pdftoppm' is not recognized as an internal or external command,
but since your fix to build with poppler 0.14 works just fine again and
this doesn't oblige to carry any other 3rth prog I'm staying within this
solution.
Thanks again
Joaquim
> On 12-07-2011 12:20, Even Rouault wrote:
>> Le mardi 12 juillet 2011 12:59:31, Joaquim Luis a écrit :
>>> Hi,
>>> I am still having troubles with a build with PDF support. I used to
>>> have
>>> a working solution for my gdalread MEX by using poppler 0.14, however
>>> now GDAL gives an error when linking with it (something about a member
>>> that does not exist).
>> Error at compile time about fillGooString() missing, with a very
>> recent trunk ?
>> If so, I've just fixed it when testing compilation on CentOS 6 that
>> ships with
>> poppler 0.12.4.
> Exactly.
>>> So I turned again to 0.16 and managed to compile
>>> everything. But now Matlab just crash when I read a pdf (repeat, before
>>> it used to work).
>> Hum I guess you run into cross-heap issues related to different
>> versions of the
>> MSVC Runtime...
> Perhaps but I am very careful in maintaining separate directories with
> libs compiled with a certain compiler (I swap between VS2010 and Intel
> 32, 64) and than always link with the libs created with the same
> compiler. That's why I want to be able to compile all dependencies
> that I use to build GDAL.
>>> Next I tried the podofo (funny name) library. Everything compiles fine
>>> but a PDF driver does not exit when print the available drivers (and
>>> obviously, reading pdf does not work).
>>> I also noted that grepping "PODOFO_ENABLED" for the entire GDAL
>>> tree, it
>>> only shows up once, in nmake.opt.
>> Yes, there was something missing in frmts/makefile.vc. I think I've
>> just fixed
>> it (untested though)
>> So 'svn update' and retry
> Thanks, I'll try it later today.
> Joaquim
>>> Ah, it's a Windows build that I'm talking about.
>>> Joaquim Luis
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
