[gdal-dev] PDF via podofo
Even Rouault even.rouault at mines-paris.org
Wed Jul 13 16:40:09 EDT 2011
Selon Joaquim Luis <jluis at ualg.pt>:
> Evan,
> It seams to work now. I say "seams" because with podofo it also requires
> to have available "pdftoppm"
> gdal_translate lixo.pdf lixo.tiff
> Input file size is 1239, 1754
> 0'pdftoppm' is not recognized as an internal or external command,
Yes, this is expected and mentioned in the driver documentation.
> but since your fix to build with poppler 0.14 works just fine again and
> this doesn't oblige to carry any other 3rth prog I'm staying within this
> solution.
> Thanks again
> Joaquim
> > On 12-07-2011 12:20, Even Rouault wrote:
> >> Le mardi 12 juillet 2011 12:59:31, Joaquim Luis a écrit :
> >>> Hi,
> >>> I am still having troubles with a build with PDF support. I used to
> >>> have
> >>> a working solution for my gdalread MEX by using poppler 0.14, however
> >>> now GDAL gives an error when linking with it (something about a member
> >>> that does not exist).
> >> Error at compile time about fillGooString() missing, with a very
> >> recent trunk ?
> >> If so, I've just fixed it when testing compilation on CentOS 6 that
> >> ships with
> >> poppler 0.12.4.
> > Exactly.
> >>> So I turned again to 0.16 and managed to compile
> >>> everything. But now Matlab just crash when I read a pdf (repeat, before
> >>> it used to work).
> >> Hum I guess you run into cross-heap issues related to different
> >> versions of the
> >> MSVC Runtime...
> > Perhaps but I am very careful in maintaining separate directories with
> > libs compiled with a certain compiler (I swap between VS2010 and Intel
> > 32, 64) and than always link with the libs created with the same
> > compiler. That's why I want to be able to compile all dependencies
> > that I use to build GDAL.
> >>> Next I tried the podofo (funny name) library. Everything compiles fine
> >>> but a PDF driver does not exit when print the available drivers (and
> >>> obviously, reading pdf does not work).
> >>> I also noted that grepping "PODOFO_ENABLED" for the entire GDAL
> >>> tree, it
> >>> only shows up once, in nmake.opt.
> >> Yes, there was something missing in frmts/makefile.vc. I think I've
> >> just fixed
> >> it (untested though)
> >> So 'svn update' and retry
> > Thanks, I'll try it later today.
> > Joaquim
> >>> Ah, it's a Windows build that I'm talking about.
> >>> Joaquim Luis
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
