[gdal-dev] Re: [gdal-1.8.0] Get new Coordinates from Geotiff avoiding black area
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jul 15 00:28:04 EDT 2011
Mett,
I understand the issue now. The easiest way is to find out the corner
pixel/line of the actual data and use these in the -srcwin option of
gdal_translate utility. You just have to make sure that the windows contains
the whole data. The new image produced by gdal_translate does not contain
the black borders. The transformation matrix and other data are updated.
On Wed, Jul 13, 2011 at 7:36 PM, mett <mettbest at gmail.com> wrote:
> Chaitanya,
> I do not understand how can I use that tool to reset the coordinates. Could
> you be more precise? Thanks!
> Luiz,
> thank you very much for your contribute, I need it for Java, I will try to
> convert it.
> Thank you again,
> Mett
> luizmotta wrote:
> > Sorry Folk,
> > I forgot the source of code.
> > I have two type of version(python source), one for QGIS and other for
> > terminal.
> > 1) QGIS/Plugin:
> > http://spatialserver.net/pyqgis_1.0/contributed/imgboundary.zip
> > 2) Teminal: http://dl.dropbox.com/u/14847115/imgtruecorner_py.zip
> > Thank Brian for remember the source.
> > Regards,
> > Luiz Motta
> http://osgeo-org.1803224.n2.nabble.com/gdal-1-8-0-Get-new-Coordinates-from-Geotiff-avoiding-black-area-tp6575681p6579103.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110715/84846077/attachment.html
