[gdal-dev] GDAL unable to recognize large GRC file
jt2000 thakkar at nexgenwireless.com
Sat Jul 16 17:40:54 EDT 2011
I have a large (>500MB) GRC file that is not being read by GDAL correctly.
*[me at server data]$ gdalinfo filename.grc
ERROR 4: `filename.grc' not recognised as a supported file format.
gdalinfo failed - unable to open 'filename.grc'.*
Is this due to the size?  I have other 200MB files that work fine.
The accompanying Mapinfo TAB file shows the following.
!table
!version 300
!charset Neutral
Definition Table
  File "filename.grc"
  Type "RASTER"
  (280380.000000,3512760.000000) (0,0) Label "Pt 1",
  (1057470.000000,2824500.000000) (25903,22942) Label "Pt 2",
  (280380.000000,2824500.000000) (0,22942) Label "Pt 3"
CoordSys Earth Projection 8,74,"m",-99,0,0.9996,500000,0
ReadOnly
begin_metadata
"\Vm\Grid" = "Character"
"\IsReadOnly" = "FALSE"
end_metadata
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6590399.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
