[gdal-dev] pct2rgb.py errors out on large rasters with rgba option
Sat Jul 16 18:48:11 EDT 2011
I don't see any obvious reason this would fail in this fashion.  I would
suggest you try and reproduce this with a very small file with lots of classes
and then file a ticket including the data.
Best regards,
On Sat, Jul 16, 2011 at 2:51 PM, jt2000 <thakkar at nexgenwireless.com> wrote:
> /usr/local/bin/pct2rgb.py -rgba raster.grc convert.tif
> *Traceback (most recent call last):
>  File "/usr/local/bin/pct2rgb.py", line 167, in <module>
>    dst_data = Numeric.take(band_lookup,src_data)
>  File "/usr/local/lib/python2.7/site-packages/numpy/core/fromnumeric.py",
> line 103, in take
>    return take(indices, axis, out, mode)
> IndexError: index out of range for array*
> There are over 2000 categories in the file.
> Any help would be appreciated.
> gdalinfo shows following:
> Driver: NWT_GRC/Northwood Classified Grid Format .grc/.tab
> Files: raster.grc
> Size is 9506, 10282
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS["unnamed",
>        DATUM["North_American_Datum_1983",
>            SPHEROID["GRS 80",6378137,298.257222101],
>            TOWGS84[0,0,0,-0,-0,-0,0]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["latitude_of_origin",0],
>    PARAMETER["central_meridian",-93],
>    PARAMETER["scale_factor",0.9996],
>    PARAMETER["false_easting",500000],
>    PARAMETER["false_northing",0],
>    UNIT["Meter",1]]
> Origin = (111765.000000000000000,3467265.000000000000000)
> Pixel Size = (30.000000000000000,-30.000000000000000)
> Corner Coordinates:
> Upper Left  (  111765.000, 3467265.000) ( 97d 4'36.80"W, 31d16'30.24"N)
> Lower Left  (  111765.000, 3158805.000) ( 96d57'54.87"W, 28d29'53.39"N)
> Upper Right (  396945.000, 3467265.000) ( 94d 4'59.78"W, 31d20' 6.94"N)
> Lower Right (  396945.000, 3158805.000) ( 94d 3'12.66"W, 28d33' 7.18"N)
> Center      (  254355.000, 3313035.000) ( 95d32'40.39"W, 29d55'24.74"N)
> Band 1 Block=9506x1 Type=UInt16, ColorInterp=Palette
>  NoData Value=0
>  Categories:
>      0: No Data
>      [Over 2000 Categories listed]
> Color Table (RGB with 2113 entries)
>    0: 255,255,255,255
>    [Rest of the entries]
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/pct2rgb-py-errors-out-on-large-rasters-with-rgba-option-tp6590418p6590418.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
