[gdal-dev] NTF/JPEG2000 Question
Even Rouault even.rouault at mines-paris.org
Sun Jul 17 05:34:10 EDT 2011
Selon Logan Greenlee <lgreenlee at digitalresultsgroup.com>:
I think that in older GDAL versions the NITF driver was computing an approximate
geotransform even if it is was not always accurate. Now the driver must be more
careful and return GCPs when returning the geotransform wouldn't be appropriate.
One option to use this image in mapserver is to use gdalwarp to produce an image
with a geotransform.
You didn't include the GCPs in your output of gdalinfo. It would have helped to
evaluate if the behaviour is consistant or not.
> I'm not sure if this is the right venue - please direct me to another list.
> I am having an issue processing DigitalGlobe NTF/JPEG2000 imagery with GDAL
> and MapServer.
> I am currently using Version 1.8.1 MSVC2008 (Win64) -release with mapserver
> 6.0.1 found here:
> http://www.gisinternals.com/sdk/
> I also have an older GDAL version 1.6.0dev provided by an old install of
> FWTools.
> I have found that there is a fairly significant difference between the two
> versions in the way that they handle NTF/JPEG2000 imagery from digital globe.
> The issue that I am having is that 1.6.0 properly displays the four corner
> points of the image. Version 1.8.1 does not dispalay, and instead displays
> the GCP points. The GCP points look correct but the image does not render
> correctly using shp2img from map server. It uses the corrdinate system that
> is shown below which is pixel relative.
> Here is the gdalinfo output from 1.8.1
> >gdalinfo img_1.NTF
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_BAG.dll using
> GDALRegister_B
> AG.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_FITS.dll using
> GDALRegister_
> FITS.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_GMT.dll using
> GDALRegister_G
> MT.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_HDF5.dll using
> GDALRegister_
> HDF5.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_HDF5Image.dll using
> GDALRegi
> ster_HDF5Image.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_MrSID.dll using
> GDALRegister
> _MrSID.
> GDAL: Auto register C:\GDALMS\bin\gdal\plugins\gdal_netCDF.dll using
> GDALRegiste
> r_netCDF.
> GDAL: GDALOpen(/vsisubfile/3958_401263470,img_1.NTF, this=00000000037E0C40)
> succeeds as JP2OpenJPEG.
> GDAL: NITFDataset::Open() wasn't able to derive a first order
> geotransform.  It will be returned as GCPs.
> GDAL: GDALOpen(img_1.NTF, this=0000000000C2C23
> 0) succeeds as NITF.
> Driver: NITF/National Imagery Transmission Format
> GDAL: GDALDefaultOverviews::OverviewScan()
> ... stuff ...
> Resulting corner coordinates:
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 7168.0)
> Upper Right ( 9216.0,    0.0)
> Lower Right ( 9216.0, 7168.0)
> Center      ( 4608.0, 3584.0)
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Blue
> Band 3 Block=1024x1024 Type=UInt16, ColorInterp=Green
> Band 4 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> Band 5 Block=1024x1024 Type=UInt16, ColorInterp=Red
> Band 6 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> Band 7 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> Band 8 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> The GCP's appear correct.
> >gdalinfo --version
> GDAL 1.6.0dev, FWTools 2.2.8, released 2008/10/29
> gdalinfo img_1.NTF
> Warning 1: Image with 11 bits per sample will not be interpreted properly.
> Files: img_1.NTF
> Size is 9216, 7168
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AXIS["Lat",NORTH],
>     AXIS["Long",EAST],
>     AUTHORITY["EPSG","4326"]]
> GeoTransform =
>   -114.3414689117551, 2.117622234280029e-005, -1.937894360779166e-008
>   33.34084229934283, 1.175619461023539e-006, -1.910763840441486e-005
> Metadata:
>   NITF_FHDR=NITF02.10
> ... stuff ....
> Image Structure Metadata:
>   COMPRESSION=JPEG2000
> RPC Metadata:
>   LINE_OFF=3425
>   LINE_SCALE=3525
>   SAMP_OFF=4412
>   SAMP_SCALE=4450
>   LONG_OFF=-114.2441
>   LONG_SCALE=0.0979
>   LAT_OFF=33.2772
>   LAT_SCALE=0.0742
>   HEIGHT_OFF=518
>   HEIGHT_SCALE=500
>   MIN_LONG=-114.29305
>   MAX_LONG=-114.19515
>   MIN_LAT=33.2401
>   MAX_LAT=33.3143
> Corner Coordinates:
> Upper Left  (-114.3414689,  33.3408423) (114d20'29.29"W, 33d20'27.03"N)
> Lower Left  (-114.3416078,  33.2038787) (114d20'29.79"W, 33d12'13.96"N)
> Upper Right (-114.1463088,  33.3516768) (114d 8'46.71"W, 33d21'6.04"N)
> Lower Right (-114.1464478,  33.2147133) (114d 8'47.21"W, 33d12'52.97"N)
> Center      (-114.2439583,  33.2777778) (114d14'38.25"W, 33d16'40.00"N)
> Band 1 Block=9216x1 Type=UInt16, ColorInterp=Undefined
>   Overviews: arbitrary
> Band 2 Block=9216x1 Type=UInt16, ColorInterp=Blue
> Band 3 Block=9216x1 Type=UInt16, ColorInterp=Green
> Band 4 Block=9216x1 Type=UInt16, ColorInterp=Undefined
> Band 5 Block=9216x1 Type=UInt16, ColorInterp=Red
> Band 6 Block=9216x1 Type=UInt16, ColorInterp=Undefined
> Band 7 Block=9216x1 Type=UInt16, ColorInterp=Undefined
> Band 8 Block=9216x1 Type=UInt16, ColorInterp=Undefined
> Any help would be appreciated!
