[gdal-dev] OGC Compliance
Peter Baumann p.baumann at jacobs-university.de
Tue Jul 19 11:10:43 EDT 2011
BTW, here is the link to the beta test suites, for what it's worth:
http://cite.opengeospatial.org/te2/
-Peter
On 07/19/2011 04:56 PM, Peter Baumann wrote:
> hm can only speak for WCS, in my capacity as chair and spec editor;
> further disclaimer: all below applies to WCS 2.0. Support for WCS 1.x is
> discontinued.
> On 07/19/2011 03:00 PM, Gaurav Garg wrote:
>> Thank Even&  Peter. I see some OGC compliance test available on their site
>> (http://cite.opengeospatial.org/teamengine/ ). As WMS, WFS and WCS will be
>> covering only server side testing; it will be of no use to use.
>> Are the tests available for KML and GML as well?
> The coverage model (OGC 09-146r1) [1] is now described in terms of GML 3.2.1.
> Hence, testing of GML representations is (better said: will be) possible. No
> KML support, though.
>> What's the best and fastest
>> way for us to test if we comply with OGC or not and get the product
>> certified?
> indeed, these are two questions.
> - test: download the test script from the OGC repository; however, as the
> suite still is under development it ain't there yet :(
> - certification: there need to be at least 3 independent open source
> implementations of a standard before OGC starts branding (it's all about
> trusting the test scripts...). We currently have: rasdaman, MapServer (in the
> make), and GMU's implementation (in the make). So we will be able to do
> branding. This means: you have to approach OGC, demonstrate that you pass the
> suite, and then you are entitled to use the certified branding.
>> Does anyone have any experience in this regards (how long it can
>> take, how much it costs, etc)?
> - time: currently the test scripts run ~2 hrs. Add download of the scripts +
> getting them to run on your machine (effort should be limited, and  you can
> get assistance from us or others)
> - costs: test suite download is free. Branding requires some bucks, but I am
> not involved in this, hence don't know.
>> Thanks,
>> Gaurav
> my pleasure.
> -Peter
> [1] http://www.opengeospatial.org/standards/wcs
>> -----Original Message-----
>> From: Peter Baumann [mailto:p.baumann at jacobs-university.de]
>> Sent: Tuesday, July 19, 2011 5:14 PM
>> To: Even Rouault
>> Cc: Gaurav Garg; gdal-dev at lists.osgeo.org
>> Subject: Re: [gdal-dev] OGC Compliance
>> hi all,
>> indeed OGC conformance tests currently cover only the server side.
>> First thoughts have been made on how to include client side testing, but
>> this can be expected to come in a few years.
>> -Peter
>> On 07/19/2011 01:34 PM, Even Rouault wrote:
>>> Selon Gaurav Garg<gaurav at vizexperts.com>:
>>> To the best of my knowledge, GDAL/OGR is not formally certified to be
>>> compliant to OGC specification. It implements clients for the WMS, WCS
>>> and WFS specifications. It also implements the GML standard (but not
>>> to its full extent). But AFAIK, the OGC compliance tests only deal
>>> with the server side of those specifications, but I might be wrong on that
>> matter.
>>>> Hi,
>>>> We have a GIS product based on GDAL/OGR. We have been asked if the
>>>> product is OGC compliant. Is GDAL/OGR compliant to OGC
>>>> specifications? If yes, what all specifications are supported?
>>>> Thanks,
>>>> Gaurav
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Dr. Peter Baumann
>>    - Professor of Computer Science, Jacobs University Bremen
>>      www.faculty.jacobs-university.de/pbaumann
>>      mail: p.baumann at jacobs-university.de
>>      tel: +49-421-200-3178, fax: +49-421-200-493178
>>    - Executive Director, rasdaman GmbH Bremen (HRB 26793)
>>      www.rasdaman.com, mail: baumann at rasdaman.com
>>      tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882 "Si
>> forte in alienas manus oberraverit hec peregrina epistola incertis ventis
>> dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec
>> preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
Dr. Peter Baumann
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
