[gdal-dev] Unable to write in subdataset
Cole, Derek dcole at integrity-apps.com
Wed Jul 20 08:32:45 EDT 2011
Doh! Thank you, I will fix that and see what happens. I suspect that solves the problem! Stared at it too long I guess!
Thanks,
Derek
From: Chaitanya kumar CH [chaitanya.ch at gmail.com]
Sent: Tuesday, July 19, 2011 11:30 PM
To: Cole, Derek
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Unable to write in subdataset
Derek,
Why are you trying to write to the dataset after opening it as GA_ReadOnly?
On Wed, Jul 20, 2011 at 4:25 AM, Cole, Derek <dcole at integrity-apps.com<mailto:dcole at integrity-apps.com>> wrote:
Hello,
I have created an image with multiple subdatasets so that I may store two images in my NITF. the way I am getting the data set of the second image  is like so:
char **papszSubdatasets = GDALGetMetadata(sharpenedDS,"SUBDATASETS");
         eraserDS = (GDALDataset *) GDALOpenShared(CSLFetchNameValue(papszSubdatasets, "SUBDATASET_2_NAME") , GA_ReadOnly );
         eraserBand = eraserDS->GetRasterBand(1);
(this is after checking to make sure that the first DS has more than one subdataset)
According to CPL_DEBUG, the GDALOpenShared works correctly and opens the file as NITF.
However, at some points in my code, I am getting this thrown to console presumably where I am using the band's RasterIO method to GF_Write.
ERROR 3: Unable to write 2097152 byte block from 8302649793.
ERROR 1: An error occured while writing a dirty block
What do these error messages mean? I mam getting a ton of them. the block is the same number of bytes, but the "from" changes in each instance of the error.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110720/8c0ce633/attachment.html
