[gdal-dev] Re: GDAL unable to recognize large GRC file
jt2000 thakkar at nexgenwireless.com
Wed Jul 20 18:54:48 EDT 2011
Yes, I'm able to open the raster file in mapinfo.
Turning on the CPL_DEBUG env variable produces the following.  It dosn't
seem to help much.
Are there any other methods I can debug this?
The file is about 580MB.  Is there a limitation on # of pixels?
ERROR 4: `filename.grc' not recognised as a supported file format.
gdalinfo failed - unable to open 'filename.grc'.
GDAL: GDALDeregister_GTiff() called.
GDAL: In GDALDestroy - unloading GDAL shared library.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6604781.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
