[gdal-dev] RE: GDAL unable to recognize large GRC file
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jul 21 01:22:08 EDT 2011
Sure, split the file send me the first 2KB.
On Thu, Jul 21, 2011 at 10:07 AM, jt2000 <thakkar at nexgenwireless.com> wrote:
> I would like to however, it’s a customer file and we’re bound by contract
> to keep it confidential.****
> I can send you hex dump of the header if you’d like.  Or let me know any
> other way I can help.****
> John****
> *From:* Chaitanya kumar CH [via OSGeo.org] [mailto:[hidden email]<http://user/SendEmail.jtp?type=node&node=6605407&i=0>]
> *Sent:* Wednesday, July 20, 2011 11:11 PM
> *To:* jt2000
> *Subject:* Re: GDAL unable to recognize large GRC file****
> John,
> Can you provide me the failing file? You can send a link to me alone.****
> On Thu, Jul 21, 2011 at 4:24 AM, jt2000 <[hidden email]<http://user/SendEmail.jtp?type=node&node=6605364&i=0>>
> wrote:****
> Yes, I'm able to open the raster file in mapinfo.
> Turning on the CPL_DEBUG env variable produces the following. Â It dosn't
> seem to help much.
> Are there any other methods I can debug this?
> The file is about 580MB. Â Is there a limitation on # of pixels?****
> ERROR 4: `filename.grc' not recognised as a supported file format.
> gdalinfo failed - unable to open 'filename.grc'.****
> GDAL: GDALDeregister_GTiff() called.
> GDAL: In GDALDestroy - unloading GDAL shared library.
> View this message in context: click here. ****
> View this message in context: RE: GDAL unable to recognize large GRC file<http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6605407.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1803224.n2.nabble.com/GDAL-Dev-f2022644.html>at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110721/c1f4ed0b/attachment.html
