[gdal-dev] Draw map in Visual C++
Brian Case rush at winkey.org
Fri Jul 22 16:18:31 EDT 2011
mark
That is a pretty general question so difficult to give you an answer.
I would like to point out that gdal will not draw the maps in your
application but will let you read the data from many different formats
with a single api.
Here is the urls to the tutorials.
raster data: http://gdal.org/gdal_tutorial.html
vector data: http://gdal.org/ogr/ogr_apitut.html
Brian
On Fri, 2011-07-22 at 11:47 -0700, mark wrote:
> Hi
> I am a beginner to OSGEO, I am using GDAL/OGR.
> What is the fastest way , to draw maps / layers  in my application.
> I am using C++.
> Thanks in advance
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Draw-map-in-Visual-C-tp6611483p6611483.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
