[gdal-dev] [gdal 1.8.0] Covert OGRlayer in Graphics2D object, how? [Java]
Even Rouault even.rouault at mines-paris.org
Sat Jul 23 13:32:57 EDT 2011
Le samedi 23 juillet 2011 19:28:50, mett a écrit :
> Hello everybody!
> I created some OGRlayers georeferenced, and I need to convert them somehow
> in a java.awt.Shape object, to handle subsequently the Graphics2D object.
> Is there any clever way to do that?
There's nothing already coded in the OGR Java API to transform a OGR Geometry
object into a java.awt.Shape object, but you should be able to code it with
the existing API. You can extract the type of geometry to instanciate the
appropriate Shape class and then you will have to add the points.
> Thank you very much,
> Matt
> http://osgeo-org.1803224.n2.nabble.com/gdal-1-8-0-Covert-OGRlayer-in-Graph
> ics2D-object-how-Java-tp6614000p6614000.html Sent from the GDAL - Dev
> mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
