[gdal-dev] gdalbuilvrt segmentation fault
Marco Nicoletti nicoletti at consorzio-innova.it
Mon Jul 25 05:34:18 EDT 2011
Dear all,
I have got a problem using the GDAL tool gdalbuildvrt.
I would like to join two DEMs sampled on the same grid which insist on the same
geografical zone.
The first DEM has got some NoDataValue holes and I would like to feel them with the values in
the second DEM.
I ave used also the flag to ignore the projection (-allow_projection_difference).
DEMs have the same raster size (xSize="10801" ySize="7201"), the same data type ("Float32")
and the same NoData Value (-3.27670000000000E+04).
The GDAL tool goes in segmentation fault: any ideas?
$ gdalbuildvrt -allow_projection_difference  output.vrt ned/safod+egm96.dem srtm/srtm_90m_egm96_grid.tif
0...10...20...30...40...50...60...70...80...90...100 - done.
Warning 6: gdalbuildvrt does not support heterogenous band characteristics. Skipping srtm/srtm_90m_egm96_grid.tif
Segmentation fault
Thanks in advanced.
Marco
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110725/b472ee07/attachment.html
