[gdal-dev] Re: Draw map in Visual C++
Ragi Burhum ragi at burhum.com
Mon Jul 25 13:07:45 EDT 2011
Brian,
There are various libraries that already support drawing spatial data. One
of them is Mapnik (which supports symbology and annotation among other
things). Take a look at their C++ drawing
sample<http://trac.mapnik.org/wiki/ExampleCode>.
If you want to draw things in a much lower level, you can also use
OpenGL<http://stackoverflow.com/questions/340185/using-gdal-ogr-api-to-read-vector-data-shapefile-how>
Best of luck,
- Ragi
> Date: Sat, 23 Jul 2011 18:12:35 +0530
> From: Chaitanya kumar CH <chaitanya.ch at gmail.com>
> Subject: Re: [gdal-dev] Re: Draw map in Visual C++
> To: mark <mark024 at hotmail.com>
> Cc: gdal-dev at lists.osgeo.org
> Message-ID:
>        <CAMKgpOYviNLw2u1YS4nJb--bofVVo=9KgN0zp-0Gyz5K_cMXcA at mail.gmail.com
> Content-Type: text/plain; charset="utf-8"
> Mark,
> You should be able to display an image by filling in a BitMap kind of
> object
> using GDALRasterIO.
> On Sat, Jul 23, 2011 at 12:40 PM, mark <mark024 at hotmail.com> wrote:
> > Thank you Brian for you reply .
> > As you said , gdal is for read / write data.
> > So do you know some libraries that allows me to draw maps in my
> > application.
> > I see many standalone open applications, like OpenEV, but it is not my
> case
> > I am using C++.
> > Thanks in advance
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110725/114952d7/attachment.html
