[gdal-dev] How to convert a GIF (being a grid with value in channel B from RGB) to XYZ?
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Jul 26 06:08:09 EDT 2011
On Tue, Jul 26, 2011 at 1:53 PM, Stefan Keller <sfkeller at gmail.com> wrote:
> Hi Chaitanya
> Thanks again for the hint. I have now to experiment with GeoTransform.
> I first let generate a valid VRT to start doing a "% gdal_translate
> -of VRT myinputfile.gif myinputfile.vrt". But I still have some
> issues:
> 1. I'm stuck on where to put the geofererencing information (being
> lower/left target coord in EPSG:21781 and pixel size 1000m). Are there
> tools which calculate "six value affine geotransformation values"
> (given lower/left target coord and pixel size 1000m)?
 These values are not hard to calculate. You can find an explanation in the
documentation for GDALDataset::GetGeoTransform() method[1].
> 2. I'm confused what's the difference between GeoTransform and
> offset/scale subtags in VRTRasterBand even after reading the VRT
> tutorial (http://www.gdal.org/gdal_vrttut.html ).
GeoTransform refers to the relationship between the pixel's position in
image verses the position in projection coordinate space.
Offset/scale is used to scale the value of the pixel. This is particularly
useful the actual pixel values are outside the current raster datatype's
value range. Refer to documentation of GDALRasterBand::GetOffset()
method[2].
> 3. Is there a way to process 600 input files without generating 600
> VRT-files (one should have a placeholder in subtag SourceFilename
> (under SimpleSource) which takes over the input parameters from the
> gdal_translate shell command.)?
Using a placeholder like you described would be easier than creating
multiple VRT files only if all the rasters are similar in location,
resolution and projection and only one raster per VRT file. Using multiple
VRT files is a lot more flexible, i.e. powerful.
> Yours, S.
[1]:
http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668
[2]:
http://www.gdal.org/classGDALRasterBand.html#b62e0761dde3e3b76f83155920275e4f
> 2011/7/25 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> > If the transformation is just shifting and scaling you can set the
> > GeoTransform element in the VRT file.
> > You can scale the pixel values using the Offset and Scale elements.
> > On Mon, Jul 25, 2011 at 5:24 PM, Stefan Keller <sfkeller at gmail.com>
> wrote:
> >> Hi Chaitanya kumar
> >> Many thanks for the hints. I know VRT from OGR but was not sure if this
> >> works here too.
> >> What I'm still wondering is, how to accomplish the transformation.
> >> It's rather a coord. translation process not comparable to warping:
> >> > The GIF size (= grid size) is 400x400 pixel with a cell size of 1000m.
> >> > The following is known about the geolocation (Switzerland,
> >> > EPSG:21781/CH1903): xmin: 481000, ymin: 38000 and xmax: 881000, ymax:
> >> > 438000.
> >> So I'd like to do some shifting and scaling before XY-coordinates are
> >> output (Z coming from the Colortable).
> >> Yours, S.
> >> > Stefan,
> >> > You can convert the integer codes to float values using a VRT file[1]
> >> > for
> >> > each gif file.
> >> > Create a VRT file with the ColorTable element. Add the SimpleSource to
> >> > point
> >> > to your gif and the SourceBand element as 3 to point to B band.
> >> > Once you create a VRT file for the GIF, you can use it like any other
> >> > raster
> >> > file. GDAL interprets the elements in it and applies the conversions
> >> > internally. Use it with gdal_translate or gdalwarp (if you want to
> warp
> >> > it
> >> > to a new coordinate system) to create an ASCII Grid file.
> >> > [1]: http://www.gdal.org/gdal_vrttut.html
> >> > On Mon, Jul 25, 2011 at 12:39 AM, Stefan Keller <sfkeller at gmail.com>
> >> > wrote:
> >> >> I have a raster/grid file transformation and conversion question:
> >> >> The input are hunddrets of GIF files which in fact are a grid about
> >> >> rainfall observations. The files have 8 BitsPerPixel (0..255). The B
> >> >> channel (integer value) from RGB obviously represents the
> >> >> precipitation intensity in [mm/h] according to a lookup table (0=>0,
> >> >> 1=>0.2, 2=>0.32, 3=>0.5, 4=>0.8, 5=1.3, 6=>2, 7=>5, 8=>8 9=>13
> 10=>20,
> >> >> 11=>32, 12=>50, 13=>50, 14=>80, 15=>130).
> 1000m.
> >> >> 438000.
> >> >> The target format is ASCII Gridded (XYZ)? or Arc/Info ASCII Grid
> >> >> (AAIGrid), with e.g. the following on each line: "481000 38000 0.32",
> >> >> meaning the transformed coordinates x and y and the float value (as
> >> >> indicated above in the lookup table).
> >> >> I know OGR but I'm new to GDAL: How would you accomplish this task?
> >> >> Transforming with gdal_transform then converting with gdal_translate
> >> >> Or do I have to write something myself (perhaps based on
> gdal2xyz.py)?
> >> >> -S.
> >> >> _______________________________________________
> >> >> gdal-dev mailing list
> >> >> gdal-dev at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> > Best regards,
> >> > Chaitanya kumar CH.
> >> > +91-9494447584
> >> > 17.2416N 80.1426E
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110726/dd8b48c2/attachment.html
