[gdal-dev] Quick question regarding image translation in Java (I think)
Even Rouault even.rouault at mines-paris.org
Thu Jul 28 14:44:10 EDT 2011
>    Am I missing something obvious?
Not sure if you'll consider it as "obvious", but it is documented there :
http://gdal.org/java/org/gdal/gdal/Driver.html#CreateCopy(java.lang.String,
%20org.gdal.gdal.Dataset,%20int,%20java.util.Vector,
%20org.gdal.gdal.ProgressCallback)
"""At the end of dataset manipulation, the delete() method *must* be called on
the returned dataset otherwise data might not be properly flushed to the
disk."""
