[gdal-dev] A map conversion problem with GDAL 1.8.0
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Jun 4 06:35:19 EDT 2011
Corrado,
I see that the two projections are essentially the same. You may not need
gdalwarp after all. Try the gdal_translate utility with the -a_srs option to
specify the Coordinate System of the output file.
Tell us how it goes.
On Sat, Jun 4, 2011 at 3:30 PM, Corrado Guarino Lo Bianco <
guarino at ce.unipr.it> wrote:
> Hi all,
> I'm a QLandkarteGT user (QLandkarteGT is based on GDAL) and I'm having a
> problem related to map formats. I use ecw maps in conjunction with DEM data
> stored in geotiff files. In the past I was using GDAL 1.7.2 and I had no
> problems. Recently I switched to GDAL 1.8.0 and now QLandkarteGT says that
> there is no matching between the projection used for the maps and that used
> for DEM data, nevertheless I'm still adopting the same files. By means of
> gdalwarp, I have made several unsuccessful attempts to convert DEM data into
> a format suitable to be used in conjunction with ecw maps.
> Can someone help me?
> These are the outputs I get from the ecw and the tiff files when I run
> gdalinfo:
> Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
> Files: /media/IGM 25000/IGM 25.000 - Emilia Romagna.ecw
> Size is 96000, 64000
> Coordinate System is:
> PROJCS["NUTM32",
>    GEOGCS["WGS 84",
>        DATUM["WGS_1984",
>            SPHEROID["WGS 84",6378137,298.257223563,
>                AUTHORITY["EPSG","7030"]],
>            TOWGS84[0,0,0,0,0,0,0],
>            AUTHORITY["EPSG","6326"]],
>        PRIMEM["Greenwich",0,
>            AUTHORITY["EPSG","8901"]],
>        UNIT["degree",0.0174532925199433,
>            AUTHORITY["EPSG","9108"]],
>        AXIS["Lat",NORTH],
>        AXIS["Long",EAST],
>        AUTHORITY["EPSG","4326"]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["latitude_of_origin",0],
>    PARAMETER["central_meridian",9],
>    PARAMETER["scale_factor",0.9996],
>    PARAMETER["false_easting",500000],
>    PARAMETER["false_northing",0],
>    UNIT["Meter",1]]
> Origin = (510000.000000000000000,5000000.000000000000000)
> Pixel Size = (2.500000000000000,-2.500000000000000)
> Corner Coordinates:
> Upper Left  (  510000.000, 5000000.000) (  9d 7'37.99"E, 45d 9'12.26"N)
> Lower Left  (  510000.000, 4840000.000) (  9d 7'26.87"E, 43d42'46.65"N)
> Upper Right (  750000.000, 5000000.000) ( 12d10'40.88"E, 45d 6'33.26"N)
> Lower Right (  750000.000, 4840000.000) ( 12d 6' 3.79"E, 43d40'15.39"N)
> Center      (  630000.000, 4920000.000) ( 10d37'59.07"E, 44d25'17.84"N)
> Band 1 Block=96000x1 Type=Byte, ColorInterp=Red
>  Overviews: 48000x32000, 24000x16000, 12000x8000, 6000x4000, 3000x2000,
> 1500x1000, 750x500, 375x250
> Band 2 Block=96000x1 Type=Byte, ColorInterp=Green
> Band 3 Block=96000x1 Type=Byte, ColorInterp=Blue
> Driver: GTiff/GeoTIFF
> Files: /media/Dati/Documenti/gps tuner/Altimetrie Italia/Emilia
> Romagna/Emilia_Romagna.tif
> Size is 4074, 4262
> PROJCS["WGS 84 / UTM zone 32N",
>    GEOGCS["WGS 84",
>        DATUM["WGS_1984",
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]],
>    AUTHORITY["EPSG","32632"]]
> Origin = (499966.037957447464578,5101878.644408876076341)
> Pixel Size = (80.031641738007920,-80.031641738007920)
> Metadata:
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  COMPRESSION=DEFLATE
>  INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  499966.038, 5101878.644) (  8d59'58.42"E, 46d 4'13.74"N)
> Lower Left  (  499966.038, 4760783.787) (  8d59'58.50"E, 42d59'58.99"N)
> Upper Right (  826014.946, 5101878.644) ( 13d12'35.68"E, 45d59'34.36"N)
> Lower Right (  826014.946, 4760783.787) ( 12d59'42.00"E, 42d55'47.82"N)
> Center      (  662990.492, 4931331.216) ( 11d 3' 3.01"E, 44d31' 0.81"N)
> Band 1 Block=256x256 Type=Int16, ColorInterp=Gray
> Thank you for your help,
> Corrado
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110604/0ddf02fe/attachment-0001.html
