[gdal-dev] RE: Adding jasper support to gdal build
Cole, Derek dcole at integrity-apps.com
Wed Jun 8 16:59:11 EDT 2011
I was finally able to get this to build, but I had to run configure of gdal with the --without-libtool option.
What kind of affect does this have on the software (other than having a successful, shorter build)?
I still dont quite understand what the cause was. This has enabled me to read JPEG2000 compressed nitf's, but I am having a problem that it seems to be taking forever for the files to load (10+minutes!!)
What is an alternate solution? This seems to be a ridiculous amount of read time, considering the uncompressed image of approximate the same size (pixels wise) loads very fast
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] on behalf of Cole, Derek [dcole at integrity-apps.com]
Sent: Wednesday, June 08, 2011 3:51 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Adding jasper support to gdal build
    Hello all,
i am trying to add jasper support to gdal so I can read jpeg2000 in NITF files. I downloaded the version of jasper off the site, and configured it like so:
./configure --enable-shared --prefix=/home/dcole/dump/jasper-1.900.1.uuid
make
make install
which created bin and lib folders in that directory(as well as already having the include folder there).
Then I tried to add it to gdal like so
./configure --with-jasper=/home/dcole/dump/jasper-1.900.1.uuid --prefix=/home/dcole/dump/gdal-1.8.0
However, when I run make, I am getting the following error:
/bin/sh /home/dcole/dump/gdal-1.8.0/libtool --mode=link g++  gdalinfo.lo  /home/dcole/dump/gdal-1.8.0/libgdal.la -o gdalinfo
libtool: link: g++ .libs/gdalinfo.o -o .libs/gdalinfo  /home/dcole/dump/gdal-1.8.0/.libs/libgdal.so  -Wl,-rpath -Wl,/home/dcole/dump/gdal-1.8/lib
/home/dcole/dump/gdal-1.8.0/.libs/libgdal.so: undefined reference to `jp2_encode_uuid'
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/home/dcole/dump/gdal-1.8.0/apps'
make: *** [apps-target] Error 2
Any ideas why this is still missing from the linkers path? Thanks
Derek
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110608/9c288afa/attachment-0001.html
