[gdal-dev] HDF5 COSMO-SKYMED metadata problems
Alex Mantaut alexmantaut at suremptec.com.ar
Wed Jun 8 17:19:36 EDT 2011
I tried the patch warmerdam posted on the 1.8.0 version an it worked, i can
see the root metadata now.
Thanks Antonio Valentino and Frank Warmerdam for the swift correction.
Another issue. Does anybody has the COSMO-SKYMED HDF5
2011/6/7 Alex Mantaut <alexmantaut at suremptec.com.ar>
> Antonio:
>            Thanks for the swift answer. I've tried to apply the patch to
> gdal 1.8 but it fails on the 5º chunk (hdf5dataset.cpp from line  598)
>            I looked at the code and it seems significantly diffrent
> (perhaps this class was modified since the patch was released a year ago?)
>             Can you release a newer version of the patch please?
>  Vi ringrazio un'altra volta
>  2011/6/7 Antonio Valentino <antonio.valentino at tiscali.it>
>> Hi Alex,
>> Il 07/06/2011 20:13, Alex Mantaut ha scritto:
>> > Hi:
>> > I'm trying to get georreference information from an HDF5 COSMO-SKYMED
>> file.
>> > I used HDFView to see the file's metadata and found that in this type of
>> > HDF5 files the georreference information is stored in the metadata
>> > corresponding to the "root" of the file.
>> > The problem is that when i try to use gdalinfo to get the file's
>> metadata,
>> > it shows the metadata asociated to all the subdatasets included on the
>> file,
>> > but not the root's metadata...
>> > My cuestions: How do i get the metadata asociated to the "root" of the
>> file?
>> > Is there a better way to get georreference from COSMO-SKYMED HDF5 files?
>> > Thanks in advance
>> Ticket #2412 [1] has an associated patch that could be useful in your
>> case (i.e for retrieving metadata associated to the root group).
>> [1] http://trac.osgeo.org/gdal/ticket/2412
>> ciao
>> Antonio Valentino
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>      Alex Mantaut
> SUR Emprendimientos Tecnológicos
> Perú 345  Piso 5to Oficina "B" (C1067AAG)
> Ciudad de Buenos Aires, Argentina
> Tel. +54 (11) 4342-2976/84
> javierurien at suremptec.com.ar
> www.suremptec.com
     Alex Mantaut
www.suremptec.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110608/63e716c7/attachment.html
