[gdal-dev] Converting from 16 bit to 8 bit images (best practices?)
Brian Case rush at winkey.org
Thu Jun 9 19:44:38 EDT 2011
Jonathan
I don't know about worldview, but with modis I wound up using multiple
ranges
0:0,750:110,1500:160,3000:210,4750:240,6375:255
see <lut>  in the vrt tutorial
Brian
On Thu, 2011-06-09 at 12:39 -0700, Jonathan Greenberg wrote:
> Brian:
> Thanks!  Great solution, definitely saved me some time.  The main
> issue (in terms of doing this entirely within GDAL) is getting the
> right scaling to make the image look good.  I was able to figure out
> the correct scale range within ENVI, and then apply the scales as you
> suggested below.  Nikos' suggestion to use rgb2pct makes me wonder if
> there is some way to figure out the optimal scale (which, AFAIK, is
> part of how rgb2pct is functioning) to apply to this image.
> Incidentally, what I'm trying to do is load Worldview-2 data onto an
> iPad 2 for use with the GISRoam mobile mapping app.  Worldview-2 is
> 16-bit per band, 8 band data, with a very high dynamic range (we have
> snow in our image, so we have lots of VERY bright pixels which throw
> off the adjustment if using -scale without any parameters).  99%
> (100%?) of mobile mapping applications need 3-band data, usually with
> only 8 bits per band.
> Pushing forward, but if someone knows how to figure out an optimal set
> of scale values to use within GDAL, please post the solution.
> --j
> On Wed, Jun 8, 2011 at 9:45 PM, Brian Case <rush at winkey.org> wrote:
>         Jonathan
>         you can do scaling on individual bands.
>         gdal_translate -b 1 -scale 0 5000 -ot Byte -of VRT infile
>         outfile1.vrt
>         gdal_translate -b 2 -scale 0 4000 -ot Byte -of VRT infile
>         outfile2.vrt
>         gdal_translate -b 3 -scale 0 3000 -ot Byte -of VRT infile
>         outfile3.vrt
>         gdalbuildvrt -separate output.vrt outfile1.vrt outfile2.vrt
>         outfile3.vrt
>         gdal_translate -of gtiff output.vrt output.tif
>         for more complicated scaling you may need to hand write a vrt
>         http://www.gdal.org/gdal_vrttut.html
>         Brian
>         On Wed, 2011-06-08 at 19:31 -0700, Jonathan Greenberg wrote:
>         > Nikos and GDALers:
>         > This is CLOSE to what I'm looking to do, but I'm having a
>         hard time
>         > getting it working properly.  Here's my input dataset
>         gdalinfo dump:
>         > Driver: ENVI/ENVI .hdr Labelled
>         > Files:
>         10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.envi
>          10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.hdr
>         > Size is 42255, 51712
>         > Coordinate System is:
>         > GEOGCS["WGS 84",
>         >     DATUM["WGS_1984",
>         >         SPHEROID["WGS 84",6378137,298.257223563,
>         >             AUTHORITY["EPSG","7030"]],
>         >         TOWGS84[0,0,0,0,0,0,0],
>         >         AUTHORITY["EPSG","6326"]],
>         >     PRIMEM["Greenwich",0,
>         >         AUTHORITY["EPSG","8901"]],
>         >     UNIT["degree",0.0174532925199433,
>         >         AUTHORITY["EPSG","9108"]],
>         >     AUTHORITY["EPSG","4326"]]
>         > Origin = (-120.066479999999999,39.271554000000002)
>         > Pixel Size = (0.000004500000005,-0.000004500000005)
>         > Image Structure Metadata:
>         >   INTERLEAVE=BAND
>         > Corner Coordinates:
>         > Upper Left  (-120.0664800,  39.2715540) (120d 3'59.33"W,
>         > 39d16'17.59"N)
>         > Lower Left  (-120.0664800,  39.0388500) (120d 3'59.33"W, 39d
>         > 2'19.86"N)
>         > Upper Right (-119.8763325,  39.2715540) (119d52'34.80"W,
>         > 39d16'17.59"N)
>         > Lower Right (-119.8763325,  39.0388500) (119d52'34.80"W, 39d
>         > 2'19.86"N)
>         > Center      (-119.9714062,  39.1552020) (119d58'17.06"W, 39d
>         > 9'18.73"N)
>         > Band 1 Block=42255x1 Type=UInt16, ColorInterp=Undefined
>         > Band 2 Block=42255x1 Type=UInt16, ColorInterp=Undefined
>         > Band 3 Block=42255x1 Type=UInt16, ColorInterp=Undefined
>         > I need to end up with a Byte TIF image with good color
>         balance from
>         > this input.  Running rgb2pct.py on this dataset just
>         outputted a
>         > "blank" (grey) image.  Running gdal_translate -of GTiff -ot
>         Byte
>         > -scale [min] [max] worked somewhat, but its near impossible
>         to get
>         > this looking right, since the scaling I want to do differs
>         from band
>         > to band (e.g. if there any way to use -scale to adjust each
>         band
>         > separately)?  Alternatively, how would I get rgb2pct.py
>         working on the
>         > above image correctly?  Thanks!
>         > --j
>         > On Wed, Jun 8, 2011 at 4:10 PM, Nikolaos Hatzopoulos
>         > <nhatzop at gmail.com> wrote:
>         >         why you don't try rgb2pct
>         http://www.gdal.org/rgb2pct.html?
>         >         --Nikos Hatzopoulos
>         >         On Wed, Jun 8, 2011 at 2:20 PM, Jonathan Greenberg
>         >         <greenberg at ucdavis.edu> wrote:
>         >                 Folks:
>         >                 I am using a piece of software which is
>         relying on an
>         >                 older version of GDAL that doesn't have the
>         "fix" to
>         >                 deal with > 8 bit geotiffs (it is trying to
>         make a
>         >                 jpeg overlay but can't from a 16 bit image.
>          I think
>         >                 this is the issue:
>         http://trac.osgeo.org/gdal/wiki/TIFF12BitJPEG), but
>         >                 when I do a straight convert (-ot Byte) the
>         output
>         >                 image looks really washed out.  Any hints
>         for getting
>         >                 the best quality output from a 16 bit to to
>         an 8 bit
>         >                 conversion of a Geotiff?
>         >                 --j
>         >                 Jonathan A. Greenberg, PhD
>         >                 Assistant Project Scientist
>         >                 Center for Spatial Technologies and Remote
>         Sensing
>         >                 (CSTARS)
>         >                 Department of Land, Air and Water Resources
>         >                 University of California, Davis
>         >                 One Shields Avenue
>         >                 Davis, CA 95616
>         >                 Phone: 415-763-5476
>         >                 AIM: jgrn307, MSN: jgrn307 at hotmail.com,
>         Gchat: jgrn307
>         _______________________________________________
>         >                 gdal-dev mailing list
>         >                 gdal-dev at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>         > Center for Spatial Technologies and Remote Sensing (CSTARS)
>         > One Shields Avenue
>         > Davis, CA 95616
>         > Phone: 415-763-5476
>         > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
> One Shields Avenue
> Davis, CA 95616
> Phone: 415-763-5476
