[gdal-dev] Converting from 16 bit to 8 bit images (best practices?)
Brian Case rush at winkey.org
Thu Jun 9 23:42:26 EDT 2011
Nikos
143, and 721
Brian
On Thu, 2011-06-09 at 16:49 -0700, Nikolaos Hatzopoulos wrote:
> for modis truecolor images?
> --Nikos
> On Thu, Jun 9, 2011 at 4:44 PM, Brian Case <rush at winkey.org> wrote:
>         Jonathan
>         I don't know about worldview, but with modis I wound up using
>         multiple
>         ranges
>         0:0,750:110,1500:160,3000:210,4750:240,6375:255
>         see <lut>  in the vrt tutorial
>         Brian
>         On Thu, 2011-06-09 at 12:39 -0700, Jonathan Greenberg wrote:
>         > Brian:
>         > Thanks!  Great solution, definitely saved me some time.  The
>         main
>         > issue (in terms of doing this entirely within GDAL) is
>         getting the
>         > right scaling to make the image look good.  I was able to
>         figure out
>         > the correct scale range within ENVI, and then apply the
>         scales as you
>         > suggested below.  Nikos' suggestion to use rgb2pct makes me
>         wonder if
>         > there is some way to figure out the optimal scale (which,
>         AFAIK, is
>         > part of how rgb2pct is functioning) to apply to this image.
>         > Incidentally, what I'm trying to do is load Worldview-2 data
>         onto an
>         > iPad 2 for use with the GISRoam mobile mapping app.
>          Worldview-2 is
>         > 16-bit per band, 8 band data, with a very high dynamic range
>         (we have
>         > snow in our image, so we have lots of VERY bright pixels
>         which throw
>         > off the adjustment if using -scale without any parameters).
>          99%
>         > (100%?) of mobile mapping applications need 3-band data,
>         usually with
>         > only 8 bits per band.
>         > Pushing forward, but if someone knows how to figure out an
>         optimal set
>         > of scale values to use within GDAL, please post the
>         solution.
>         > --j
>         > On Wed, Jun 8, 2011 at 9:45 PM, Brian Case <rush at winkey.org>
>         wrote:
>         >         Jonathan
>         >         you can do scaling on individual bands.
>         >         gdal_translate -b 1 -scale 0 5000 -ot Byte -of VRT
>         infile
>         >         outfile1.vrt
>         >         gdal_translate -b 2 -scale 0 4000 -ot Byte -of VRT
>         infile
>         >         outfile2.vrt
>         >         gdal_translate -b 3 -scale 0 3000 -ot Byte -of VRT
>         infile
>         >         outfile3.vrt
>         >         gdalbuildvrt -separate output.vrt outfile1.vrt
>         outfile2.vrt
>         >         outfile3.vrt
>         >         gdal_translate -of gtiff output.vrt output.tif
>         >         for more complicated scaling you may need to hand
>         write a vrt
>         >         http://www.gdal.org/gdal_vrttut.html
>         >         Brian
>         >         On Wed, 2011-06-08 at 19:31 -0700, Jonathan
>         Greenberg wrote:
>         >         > Nikos and GDALers:
>         >         > This is CLOSE to what I'm looking to do, but I'm
>         having a
>         >         hard time
>         >         > getting it working properly.  Here's my input
>         dataset
>         >         gdalinfo dump:
>         >         > Driver: ENVI/ENVI .hdr Labelled
>         >         > Files:
>         10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.envi
>          10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.hdr
>         >         > Size is 42255, 51712
>         >         > Coordinate System is:
>         >         > GEOGCS["WGS 84",
>         >         >     DATUM["WGS_1984",
>         >         >         SPHEROID["WGS 84",6378137,298.257223563,
>         >         >             AUTHORITY["EPSG","7030"]],
>         >         >         TOWGS84[0,0,0,0,0,0,0],
>         >         >         AUTHORITY["EPSG","6326"]],
>         >         >     PRIMEM["Greenwich",0,
>         >         >         AUTHORITY["EPSG","8901"]],
>         >         >     UNIT["degree",0.0174532925199433,
>         >         >         AUTHORITY["EPSG","9108"]],
>         >         >     AUTHORITY["EPSG","4326"]]
>         >         > Origin = (-120.066479999999999,39.271554000000002)
>         >         > Pixel Size =
>         (0.000004500000005,-0.000004500000005)
>         >         > Image Structure Metadata:
>         >         >   INTERLEAVE=BAND
>         >         > Corner Coordinates:
>         >         > Upper Left  (-120.0664800,  39.2715540) (120d
>         3'59.33"W,
>         >         > 39d16'17.59"N)
>         >         > Lower Left  (-120.0664800,  39.0388500) (120d
>         3'59.33"W, 39d
>         >         > 2'19.86"N)
>         >         > Upper Right (-119.8763325,  39.2715540)
>         (119d52'34.80"W,
>         >         > 39d16'17.59"N)
>         >         > Lower Right (-119.8763325,  39.0388500)
>         (119d52'34.80"W, 39d
>         >         > 2'19.86"N)
>         >         > Center      (-119.9714062,  39.1552020)
>         (119d58'17.06"W, 39d
>         >         > 9'18.73"N)
>         >         > Band 1 Block=42255x1 Type=UInt16,
>         ColorInterp=Undefined
>         >         > Band 2 Block=42255x1 Type=UInt16,
>         >         > Band 3 Block=42255x1 Type=UInt16,
>         >         > I need to end up with a Byte TIF image with good
>         color
>         >         balance from
>         >         > this input.  Running rgb2pct.py on this dataset
>         just
>         >         outputted a
>         >         > "blank" (grey) image.  Running gdal_translate -of
>         GTiff -ot
>         >         Byte
>         >         > -scale [min] [max] worked somewhat, but its near
>         impossible
>         >         to get
>         >         > this looking right, since the scaling I want to do
>         differs
>         >         from band
>         >         > to band (e.g. if there any way to use -scale to
>         adjust each
>         >         band
>         >         > separately)?  Alternatively, how would I get
>         rgb2pct.py
>         >         working on the
>         >         > above image correctly?  Thanks!
>         >         > --j
>         >         > On Wed, Jun 8, 2011 at 4:10 PM, Nikolaos
>         Hatzopoulos
>         >         > <nhatzop at gmail.com> wrote:
>         >         >         why you don't try rgb2pct
>         >         http://www.gdal.org/rgb2pct.html?
>         >         >         --Nikos Hatzopoulos
>         >         >         On Wed, Jun 8, 2011 at 2:20 PM, Jonathan
>         Greenberg
>         >         >         <greenberg at ucdavis.edu> wrote:
>         >         >                 Folks:
>         >         >                 I am using a piece of software
>         which is
>         >         relying on an
>         >         >                 older version of GDAL that doesn't
>         have the
>         >         "fix" to
>         >         >                 deal with > 8 bit geotiffs (it is
>         trying to
>         >         make a
>         >         >                 jpeg overlay but can't from a 16
>         bit image.
>         >          I think
>         >         >                 this is the issue:
>         >         http://trac.osgeo.org/gdal/wiki/TIFF12BitJPEG), but
>         >         >                 when I do a straight convert (-ot
>         Byte) the
>         >         output
>         >         >                 image looks really washed out.
>          Any hints
>         >         for getting
>         >         >                 the best quality output from a 16
>         bit to to
>         >         an 8 bit
>         >         >                 conversion of a Geotiff?
>         >         >                 --j
>         >         >                 Jonathan A. Greenberg, PhD
>         >         >                 Assistant Project Scientist
>         >         >                 Center for Spatial Technologies
>         and Remote
>         >         Sensing
>         >         >                 (CSTARS)
>         >         >                 Department of Land, Air and Water
>         Resources
>         >         >                 University of California, Davis
>         >         >                 One Shields Avenue
>         >         >                 Davis, CA 95616
>         >         >                 Phone: 415-763-5476
>         >         >                 AIM: jgrn307, MSN:
>         jgrn307 at hotmail.com,
>         >         Gchat: jgrn307
>         >         _______________________________________________
>         >         >                 gdal-dev mailing list
>         >         >                 gdal-dev at lists.osgeo.org
>         >         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>         >         > Center for Spatial Technologies and Remote Sensing
>         (CSTARS)
>         >         > Department of Land, Air and Water Resources
>         >         > One Shields Avenue
>         >         > Davis, CA 95616
>         >         > Phone: 415-763-5476
>         >         > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat:
>         jgrn307
>         > Center for Spatial Technologies and Remote Sensing (CSTARS)
>         > One Shields Avenue
>         > Davis, CA 95616
>         > Phone: 415-763-5476
>         > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
