[gdal-dev] Converting from 16 bit to 8 bit images (best practices?)
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jun 10 13:23:55 EDT 2011
Nikos,
You can use the VRT format [1] in GDAL to perform this. The ComplexSource
elements can have an LUT element. It can be used to specify your lookup
table. The values in between are interpolated linearly.
[1]: http://www.gdal.org/gdal_vrttut.html
On Fri, Jun 10, 2011 at 10:19 PM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
> Rapid response for true color has this:
> ;- Rapid Response default enhancement: 0,0, 30,110, 60,160, 120,210,
> 190,240, 255,255
> x = byte([0,  30,  60, 120, 190, 255])
> y = byte([0, 110, 160, 210, 240, 255])
> ;- Rapid Response cloud enhancement: 0,0, 25,90, 55,140, 100,175, 255,255
> if keyword_set(cloud) then begin
>   x = byte([0, 25,  55, 100, 255])
>   y = byte([0, 90, 140, 175, 255])
> endif
> how it can be programmed in gdal language?
> --Nikos
> On Thu, Jun 9, 2011 at 8:42 PM, Brian Case <rush at winkey.org> wrote:
>> Nikos
>> 143, and 721
>> Brian
>> On Thu, 2011-06-09 at 16:49 -0700, Nikolaos Hatzopoulos wrote:
>> > for modis truecolor images?
>> > --Nikos
>> > On Thu, Jun 9, 2011 at 4:44 PM, Brian Case <rush at winkey.org> wrote:
>> >         Jonathan
>> >         I don't know about worldview, but with modis I wound up using
>> >         multiple
>> >         ranges
>> >         0:0,750:110,1500:160,3000:210,4750:240,6375:255
>> >         see <lut>  in the vrt tutorial
>> >         Brian
>> >         On Thu, 2011-06-09 at 12:39 -0700, Jonathan Greenberg wrote:
>> >         > Brian:
>> >         > Thanks!  Great solution, definitely saved me some time.  The
>> >         main
>> >         > issue (in terms of doing this entirely within GDAL) is
>> >         getting the
>> >         > right scaling to make the image look good.  I was able to
>> >         figure out
>> >         > the correct scale range within ENVI, and then apply the
>> >         scales as you
>> >         > suggested below.  Nikos' suggestion to use rgb2pct makes me
>> >         wonder if
>> >         > there is some way to figure out the optimal scale (which,
>> >         AFAIK, is
>> >         > part of how rgb2pct is functioning) to apply to this image.
>> >         > Incidentally, what I'm trying to do is load Worldview-2 data
>> >         onto an
>> >         > iPad 2 for use with the GISRoam mobile mapping app.
>> >          Worldview-2 is
>> >         > 16-bit per band, 8 band data, with a very high dynamic range
>> >         (we have
>> >         > snow in our image, so we have lots of VERY bright pixels
>> >         which throw
>> >         > off the adjustment if using -scale without any parameters).
>> >          99%
>> >         > (100%?) of mobile mapping applications need 3-band data,
>> >         usually with
>> >         > only 8 bits per band.
>> >         > Pushing forward, but if someone knows how to figure out an
>> >         optimal set
>> >         > of scale values to use within GDAL, please post the
>> >         solution.
>> >         > --j
>> >         > On Wed, Jun 8, 2011 at 9:45 PM, Brian Case <rush at winkey.org>
>> >         wrote:
>> >         >         Jonathan
>> >         >         you can do scaling on individual bands.
>> >         >         gdal_translate -b 1 -scale 0 5000 -ot Byte -of VRT
>> >         infile
>> >         >         outfile1.vrt
>> >         >         gdal_translate -b 2 -scale 0 4000 -ot Byte -of VRT
>> >         infile
>> >         >         outfile2.vrt
>> >         >         gdal_translate -b 3 -scale 0 3000 -ot Byte -of VRT
>> >         infile
>> >         >         outfile3.vrt
>> >         >         gdalbuildvrt -separate output.vrt outfile1.vrt
>> >         outfile2.vrt
>> >         >         outfile3.vrt
>> >         >         gdal_translate -of gtiff output.vrt output.tif
>> >         >         for more complicated scaling you may need to hand
>> >         write a vrt
>> >         >         Brian
>> >         >         On Wed, 2011-06-08 at 19:31 -0700, Jonathan
>> >         Greenberg wrote:
>> >         >         > Nikos and GDALers:
>> >         >         > This is CLOSE to what I'm looking to do, but I'm
>> >         having a
>> >         >         hard time
>> >         >         > getting it working properly.  Here's my input
>> >         dataset
>> >         >         gdalinfo dump:
>> >         >         > Driver: ENVI/ENVI .hdr Labelled
>> >         >         > Files:
>> >         10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.envi
>> >          10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.hdr
>> >         >         > Size is 42255, 51712
>> >         >         > Coordinate System is:
>> >         >         > GEOGCS["WGS 84",
>> >         >         >     DATUM["WGS_1984",
>> >         >         >         SPHEROID["WGS 84",6378137,298.257223563,
>> >         >         >             AUTHORITY["EPSG","7030"]],
>> >         >         >         TOWGS84[0,0,0,0,0,0,0],
>> >         >         >         AUTHORITY["EPSG","6326"]],
>> >         >         >     PRIMEM["Greenwich",0,
>> >         >         >         AUTHORITY["EPSG","8901"]],
>> >         >         >     UNIT["degree",0.0174532925199433,
>> >         >         >         AUTHORITY["EPSG","9108"]],
>> >         >         >     AUTHORITY["EPSG","4326"]]
>> >         >         > Origin = (-120.066479999999999,39.271554000000002)
>> >         >         > Pixel Size =
>> >         (0.000004500000005,-0.000004500000005)
>> >         >         > Image Structure Metadata:
>> >         >         >   INTERLEAVE=BAND
>> >         >         > Corner Coordinates:
>> >         >         > Upper Left  (-120.0664800,  39.2715540) (120d
>> >         3'59.33"W,
>> >         >         > 39d16'17.59"N)
>> >         >         > Lower Left  (-120.0664800,  39.0388500) (120d
>> >         3'59.33"W, 39d
>> >         >         > 2'19.86"N)
>> >         >         > Upper Right (-119.8763325,  39.2715540)
>> >         (119d52'34.80"W,
>> >         >         > 39d16'17.59"N)
>> >         >         > Lower Right (-119.8763325,  39.0388500)
>> >         (119d52'34.80"W, 39d
>> >         >         > 2'19.86"N)
>> >         >         > Center      (-119.9714062,  39.1552020)
>> >         (119d58'17.06"W, 39d
>> >         >         > 9'18.73"N)
>> >         >         > Band 1 Block=42255x1 Type=UInt16,
>> >         ColorInterp=Undefined
>> >         >         > Band 2 Block=42255x1 Type=UInt16,
>> >         >         > Band 3 Block=42255x1 Type=UInt16,
>> >         >         > I need to end up with a Byte TIF image with good
>> >         color
>> >         >         balance from
>> >         >         > this input.  Running rgb2pct.py on this dataset
>> >         just
>> >         >         outputted a
>> >         >         > "blank" (grey) image.  Running gdal_translate -of
>> >         GTiff -ot
>> >         >         Byte
>> >         >         > -scale [min] [max] worked somewhat, but its near
>> >         impossible
>> >         >         to get
>> >         >         > this looking right, since the scaling I want to do
>> >         differs
>> >         >         from band
>> >         >         > to band (e.g. if there any way to use -scale to
>> >         adjust each
>> >         >         band
>> >         >         > separately)?  Alternatively, how would I get
>> >         rgb2pct.py
>> >         >         working on the
>> >         >         > above image correctly?  Thanks!
>> >         >         > --j
>> >         >         > On Wed, Jun 8, 2011 at 4:10 PM, Nikolaos
>> >         Hatzopoulos
>> >         >         > <nhatzop at gmail.com> wrote:
>> >         >         >         why you don't try rgb2pct
>> >         >         http://www.gdal.org/rgb2pct.html?
>> >         >         >         --Nikos Hatzopoulos
>> >         >         >         On Wed, Jun 8, 2011 at 2:20 PM, Jonathan
>> >         Greenberg
>> >         >         >         <greenberg at ucdavis.edu> wrote:
>> >         >         >                 Folks:
>> >         >         >                 I am using a piece of software
>> >         which is
>> >         >         relying on an
>> >         >         >                 older version of GDAL that doesn't
>> >         have the
>> >         >         "fix" to
>> >         >         >                 deal with > 8 bit geotiffs (it is
>> >         trying to
>> >         >         make a
>> >         >         >                 jpeg overlay but can't from a 16
>> >         bit image.
>> >         >          I think
>> >         >         >                 this is the issue:
>> >         >         http://trac.osgeo.org/gdal/wiki/TIFF12BitJPEG), but
>> >         >         >                 when I do a straight convert (-ot
>> >         Byte) the
>> >         >         output
>> >         >         >                 image looks really washed out.
>> >          Any hints
>> >         >         for getting
>> >         >         >                 the best quality output from a 16
>> >         bit to to
>> >         >         an 8 bit
>> >         >         >                 conversion of a Geotiff?
>> >         >         >                 --j
>> >         >         >                 Jonathan A. Greenberg, PhD
>> >         >         >                 Assistant Project Scientist
>> >         >         >                 Center for Spatial Technologies
>> >         and Remote
>> >         >         Sensing
>> >         >         >                 (CSTARS)
>> >         >         >                 Department of Land, Air and Water
>> >         Resources
>> >         >         >                 University of California, Davis
>> >         >         >                 One Shields Avenue
>> >         >         >                 Davis, CA 95616
>> >         >         >                 Phone: 415-763-5476
>> >         >         >                 AIM: jgrn307, MSN:
>> >         jgrn307 at hotmail.com,
>> >         >         Gchat: jgrn307
>> >         >         _______________________________________________
>> >         >         >                 gdal-dev mailing list
>> >         >         >                 gdal-dev at lists.osgeo.org
>> >         >         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> >         >         > Center for Spatial Technologies and Remote Sensing
>> >         (CSTARS)
>> >         >         > Department of Land, Air and Water Resources
>> >         >         > One Shields Avenue
>> >         >         > Davis, CA 95616
>> >         >         > Phone: 415-763-5476
>> >         >         > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat:
>> >         jgrn307
>> >         > Center for Spatial Technologies and Remote Sensing (CSTARS)
>> >         > One Shields Avenue
>> >         > Davis, CA 95616
>> >         > Phone: 415-763-5476
>> >         > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110610/4a67ba89/attachment-0001.html
