[gdal-dev] Re: wfs 1.1.0 via mapserver and ogr
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Sat Jun 11 03:11:32 EDT 2011
Jachym Cepicky <jachym.cepicky <at> gmail.com> writes:
> is WRONG because of the axes are inverted, the filter *should* look like
> 12.9295317871890720,48.7275012197312094 18.1965700336475784,51.1769623652315175
Mapserver is doing that part RIGHT, because in WFS 1.1.0 the EPSG:4326 axis
order is Easting-Northing. You can find easily more reading from the web about
the item.
What IS wrong is using gml Box in the filter. Box does not exist in GML3 and
Envelope should be used instead.
-Jukka Rahkonen-
