[gdal-dev] OpenJPEG2000 issues when reading blocks at a time
Cole, Derek dcole at integrity-apps.com
Tue Jun 14 10:49:58 EDT 2011
Sorry to spam the list, but I am wondering if this is related to the threading perhaps? I have tried to run this identical code in a single-threaded fashion, and it seems to work OK. Does the library perhaps have something going on that is signaling the file has been read prematurely? I have watchers that are waiting on a finished signal, which I have tested that they are (and this works for a non-compressed image). Most of the image tiles are coming back zeros, which makes me think it is somehow initializing some memory, and signaling it is done before the arrays have actually been populated?
Derek
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] on behalf of Cole, Derek [dcole at integrity-apps.com]
Sent: Tuesday, June 14, 2011 10:28 AM
To: Chaitanya kumar CH
Cc: gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] OpenJPEG2000 issues when reading blocks at a time
I am afraid I won't be able to post a screenshot, or the original image that is causing this issue.
I will also note, occaisionally the image fails to load at all, and I get a dump like this:
ERROR 1: Marker is not compliant with its position
ERROR 1: opj_read_header() failed
ERROR 1: IReadBlock failed at X offset 1, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 1, Y block offset 0
Segmentation Fault
Googling for those error message reveals about 2 results, and this email thread is one of them =\
From: Chaitanya kumar CH [chaitanya.ch at gmail.com]
Sent: Monday, June 13, 2011 11:13 PM
To: Cole, Derek
Subject: Re: [gdal-dev] OpenJPEG2000 issues when reading blocks at a time
Derek,
Can you provide a screenshot of the displayed image. Especially the scrambled blocks.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110614/2549ffd3/attachment.html
