[gdal-dev] changing data type of a shapefile
Eli Adam EAdam at co.lincoln.or.us
Wed Jun 15 11:18:13 EDT 2011
Ahmet,
     You can also change geometry type, it is also an option with
ogr2ogr [2], -nlt.  I've only used -nlt to promote to multi-geometry.
Eli
>>> On 6/15/2011 at 7:27 AM, in message
<BANLkTik8UghqaRv8E-pES6OSv-+e=a3QdQ at mail.gmail.com>, Chaitanya kumar
CH
<chaitanya.ch at gmail.com> wrote:
> Ahmet,
> You can use OGR SQL [1] to typecast fields and other stuff. You can
use
> ogr2ogr [2] with the -sql option and supply the sql statement.
> [1]: http://trac.osgeo.org/gdal/wiki/rfc21_ogrsqlcast
> [2]: http://www.gdal.org/ogr2ogr.html
> 2011/6/15 ahmet temiz <ahmettemiz88 at gmail.com>
>> hello
>> how can I change data type of a shapefile by ogr2ogr ?
>> regards
>> Ahmet Temiz
>> Jeoloji Müh.
>> Afet ve Acil Durum Yönetimi Başkanlığı
>> Planlama ve Zarar Azaltma Dairesi Başkanlığı
>> Bilgi ve CBS grubu
>> Eskişehir Yolu 10. km.
>> Lodumlu / Ankara
>> Tel : 0 312 2872680 / 1535
>> ________________________
>> Ahmet Temiz
>> Geological Eng.
>> Information Systems - GIS Group
>> Disaster and Emergency Management
>> of Presidency
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
