[gdal-dev] hdf5image metadata problems
Alex Mantaut alexmantaut at suremptec.com.ar
Wed Jun 15 17:26:33 EDT 2011
Frank:
         I opened a new defect ticket, and suggested a way around the
problem (I'm not sure if it's the best solution)
http://trac.osgeo.org/gdal/ticket/4121
Regards
2011/6/15 Frank Warmerdam <warmerdam at pobox.com>
> On 11-06-15 03:50 PM, Alex Mantaut wrote:
>> Hi Frank:
>>             Thanks for the swift reply.
>>              Right now it opens the metadata asociated to the root, and
>> also
>> the metadata asociated with all the other groups, but it doesn't open the
>> metadata asociated to the specified element (bug?)
> Alex,
> It sounds like a defect to me, yes.
> I would suggest filing a ticket that carefully documents the
> problem with a supporting example file.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
     Alex Mantaut
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110615/73146c69/attachment-0001.html
