[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Mon Jun 20 06:27:42 EDT 2011
On 11-06-18 12:59 PM, Antonio Valentino wrote:
> Regarding the JAXAPalsar driver, it is currently registered *after* the
> ceos2 driver so, if my understanding is correct, CEOS products should be
> opened with ceos2 and the JAXAPalsar should be used as a fallback.
> Is it correct?
Antonio,
Yes, if it is registered after the SAR_CEOS driver (frmts/ceos2) then it
would only be used for datasets not recgonised by the SAR_CEOS driver.
Best regards,
