[gdal-dev] Remove projection info
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Jun 21 07:20:30 EDT 2011
Convert the file into a PNG image. Delete the .aux.xml file.
You can convert the PNG into TIFF if you want.
On Tue, Jun 21, 2011 at 4:35 PM, Goo Creations <goocreations at gmail.com>wrote:
> Hi all,
> I'm looking for a way to remove any projection and CRS information from an
> image. I've tried:
> gdal_translate -a_srs "" in.tif out.tif
> but without any success. Does anyone know how to do this (or by using
> CreateCopy() via source code)?
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110621/f01c4c57/attachment.html
