Re: [gdal-dev] Problem Compiling with Oracle (--with-oci)
Ivan Lucena ivan.lucena at pmldnet.com
Tue Jun 21 14:30:05 EDT 2011
Hi Chris,
I would not advise changing the configuration file.
If you have a full installation of Oracle in your system you probably have a ORACLE_HOME environment variable, so if you run:
$ ./configure
checking for Oracle OCI headers in /oracle/path/... yes
checking for Oracle OCI libraries in /oracle/path/lib... yes
checking if Oracle OCI version is >= 8.1.7 ... yes
checking for Oracle version >= 10.x to use -lnnz10 flag... yes
checking if Oracle support is enabled... yes
  OCI support:               yes
  GEORASTER support:         yes
If you don't have ORACLE_HOME you can pass the path using
$ ./configure --with-oci=/oracle/path/...
Now, you system is CentOS and I have never build GDAL on it but I would guess that it doesn't have Expat installed yet. My Linux does, so configure finds it:
checking for XML_ParserCreate in -lexpat... yes
checking for Expat XML Parser headers in /usr/include... found
checking for Expat XML Parser... yes
My suggestion is to isolate the problem by running ./configure, make and gdalinfo without Expat once and then make clean, ./configure, make and gdalinfo without OCI, ex:
% ./configure --with-expat=NO
% ./configure --with-OCI=NO
Configure will setup your makefiles, then you run make based on those new settings.
Good luck.
Ivan
>  -------Original Message-------
>  From: Chris Hodgson <chodgson at refractions.net>
>  To: gdal-dev at lists.osgeo.org
>  Subject: Re: [gdal-dev] Problem Compiling with Oracle (--with-oci)
>  Sent: Jun 21 '11 12:38
>  What would need changed in the configure file? There is no reference
>  there to the non-existent libexpat.
>  I'm not familiar with spec files... but if I wanted to learn - what
>  could I do there that I couldn't do in the configure/make process? The
>  spec file still uses the package's build system right?
>  It's not until the final linking with libtool that the problem happens,
>  I just don't know what I need to tell libtool to get it to smarten up...
>  Surely other people have compiled with support for oracle 11g? CentOS is
>  just repackaged RHEL.... I don't know what I'm doing that is out of the
>  ordinary here.
>  Chris
>  Nikolaos Hatzopoulos wrote:
>  > check the configure file it might need changes (vi configure)
>  > you can add the elgis repo add the devel package and start getting
>  > involved with
>  > the compile.
>  > this is a src rpm:
>  > http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.src.rpm
>  > if you are familiar with spec files I strongly suggest you to do it
>  > that way :)
>  > --Nikos Hatzopoulos
>  > On Mon, Jun 20, 2011 at 4:49 PM, Chris Hodgson
>  > <chodgson at refractions.net <mailto:chodgson at refractions.net>> wrote:
>  >     grep tells me that the /ade/smayer.../ path is not in any text
>  >     file in my gdal distribution (even after configuring) - which I
>  >     grabbed the latest 1.8.0 from osgeo.org <http://osgeo.org>.
>  >     Chris
>  >     Ivan Lucena wrote:
>  >         Chris,
>  >         I am not on my Linux machine now to confirm but I would never
>  >         needed to use --with-expat pointing to Oracle's path. It is
>  >         fanny that you found that smaver path. Sounds like you got a
>  >         tar.gz package from someone, not from a GDAL distribution.
>  >         The OCI driver should not depend in nothing but OCI apart from
>  >         GDAL/OGR stuff.
>  >         Regards,
>  >         Ivan
>  >             <mailto:gdal-dev at lists.osgeo.org>
>  >              Subject: [gdal-dev] Problem Compiling with Oracle
>  >             (--with-oci)
>  >              Sent: Jun 20 '11 17:43
>  >              I'm trying to compile GDAL/OGR with support for
>  >             Oracle/OCI. I have the
>  >              full oracle 11g server installed on CentOS 5.3.
>  >              # configure --with-oci=/opt/oracle/product/11.2.0/dbhome_1/
>  >              # make
>  >              libtool:.....
>  >              g++:
>  >             /ade/smayer_perl_510/perl_source/expat_home/lib/libexpat.so:
>  >             No
>  >              such file or directory
>  >              I think this path might be from the person who compiled
>  >             the OCI
>  >              libraries for oracle 11? I have nothing remotely like it
>  >             on my system.
>  >              If I add --with-expat=no to my configure line I get
>  >             errors during
>  >              linking about undefined references to XML_... so I'm
>  >             guessing the linked
>  >              OCI drivers need the expat lib linked in.
>  >              I added /opt/oracle/product/11.2.0/dbhome_1/lib to my
>  >             LD_LIBRARY_PATH,
>  >              and there is a libexpat.so.1.5.2 there, as well as my
>  >              /lib/libexpat.so.0.5.0 which is from my CentOS standarad
>  >             RPMS:
>  >              # rpm -qa | grep expat
>  >              expat-1.95.8-8.2.1
>  >              expat-devel-1.95.8-8.2.1
>  >              I also tried
>  >             --with-expat=/opt/oracle/product/11.2.0/dbhome_1/ but there
>  >              are no headers there, among other problems.
>  >              How can I get this to work?
>  >              Thanks,
>  >              Chris
>  >              _______________________________________________
>  >              gdal-dev mailing list
>  >              gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>  >              http://lists.osgeo.org/mailman/listinfo/gdal-dev
