[gdal-dev] Problem Compiling with Oracle (--with-oci)
Nikolaos Hatzopoulos nhatzop at gmail.com
Tue Jun 21 15:15:55 EDT 2011
vi configure :)
--Nikos
On Tue, Jun 21, 2011 at 12:02 PM, Chris Hodgson <chodgson at refractions.net>wrote:
> Ivan I appreciate your help here, but I think I've already tried everything
> you are suggesting. I dont' have an ORACLE_HOME set on the user doing this
> compiling, so if I don't specify --with-oci=... I don't get oracle support.
> I do have expat 1.95 installed (with -devel package as well) and it is
> automatically picked up by configure.
> I can build gdal successfully with no configure options, it builds with
> expat support among other defaults.
> If I specify --with-oci, I get the error about the funny libexpat path, if
> I add --with-expat=no, I get past that error, but get an error later when it
> can't find the XML_* symbols that the oracle library needs to be linked to.
> In neither of these cases to i get a working version of gdalinfo built.
> It seems to me that I need to link in expat for the oracle library, but I'm
> not sure if it is compatible with the 1.95 version the my system has
> installed and that GDAL requires if I specify --with-expat  ... because
> there is an libexpat.so.0.5 in the oracle lib directory. Since I don't
> actually need GDAL's expat support, I'm fine with --with-expat=no ... but
> then I need to somehow tell libtool to ignore the funny expat path it is
> finding and use the expat in the oracle directory... perhaps the best way to
> do this is just to copy the libtool command that is failing in the build and
> tweak it manually to have the right path to the oracle expat instead of the
> funny path... however I won't be able to get to the next step of the build
> to see what other commands I need to run... is there a way to modify the
> makefile or tell configure about this?
> Thanks,
> Chris
> Ivan Lucena wrote:
>> Hi Chris,
>> I would not advise changing the configuration file.
>> If you have a full installation of Oracle in your system you probably have
>> a ORACLE_HOME environment variable, so if you run:
>> $ ./configure
>> checking for Oracle OCI headers in /oracle/path/... yes
>> checking for Oracle OCI libraries in /oracle/path/lib... yes
>> checking if Oracle OCI version is >= 8.1.7 ... yes
>> checking for Oracle version >= 10.x to use -lnnz10 flag... yes
>> checking if Oracle support is enabled... yes
>>  OCI support:               yes
>>  GEORASTER support:         yes
>> If you don't have ORACLE_HOME you can pass the path using
>> $ ./configure --with-oci=/oracle/path/...
>> Now, you system is CentOS and I have never build GDAL on it but I would
>> guess that it doesn't have Expat installed yet. My Linux does, so configure
>> finds it:
>> checking for XML_ParserCreate in -lexpat... yes
>> checking for Expat XML Parser headers in /usr/include... found
>> checking for Expat XML Parser... yes
>> My suggestion is to isolate the problem by running ./configure, make and
>> gdalinfo without Expat once and then make clean, ./configure, make and
>> gdalinfo without OCI, ex:
>> % ./configure --with-expat=NO % ./configure --with-OCI=NO
>> Configure will setup your makefiles, then you run make based on those new
>> settings.
>> Good luck.
>> Ivan
>>>  -------Original Message-------
>>>  From: Chris Hodgson <chodgson at refractions.net>
>>>  To: gdal-dev at lists.osgeo.org
>>>  Subject: Re: [gdal-dev] Problem Compiling with Oracle (--with-oci)
>>>  Sent: Jun 21 '11 12:38
>>>  What would need changed in the configure file? There is no reference
>>>  there to the non-existent libexpat.
>>>  I'm not familiar with spec files... but if I wanted to learn - what
>>>  could I do there that I couldn't do in the configure/make process? The
>>>  spec file still uses the package's build system right?
>>>  It's not until the final linking with libtool that the problem happens,
>>>  I just don't know what I need to tell libtool to get it to smarten up...
>>>  Surely other people have compiled with support for oracle 11g? CentOS is
>>>  just repackaged RHEL.... I don't know what I'm doing that is out of the
>>>  ordinary here.
>>>  Chris
>>>  Nikolaos Hatzopoulos wrote:
>>>  > check the configure file it might need changes (vi configure)
>>>  > you can add the elgis repo add the devel package and start getting
>>>  > involved with
>>>  > the compile.
>>>  > this is a src rpm:
>>>  > http://elgis.argeo.org/repos/**testing/5/elgis/SRPMS/gdal-1.**
>>> 8.0-2.el5.elgis.src.rpm<http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.src.rpm>
>>>  > if you are familiar with spec files I strongly suggest you to do it
>>>  > that way :)
>>>  > --Nikos Hatzopoulos
>>>  > On Mon, Jun 20, 2011 at 4:49 PM, Chris Hodgson
>>>  > <chodgson at refractions.net <mailto:chodgson at refractions.**net<chodgson at refractions.net>>>
>>> wrote:
>>>  >     grep tells me that the /ade/smayer.../ path is not in any text
>>>  >     file in my gdal distribution (even after configuring) - which I
>>>  >     grabbed the latest 1.8.0 from osgeo.org <http://osgeo.org>.
>>>  >     Chris
>>>  >     Ivan Lucena wrote:
>>>  >         Chris,
>>>  >         I am not on my Linux machine now to confirm but I would never
>>>  >         needed to use --with-expat pointing to Oracle's path. It is
>>>  >         fanny that you found that smaver path. Sounds like you got a
>>>  >         tar.gz package from someone, not from a GDAL distribution.
>>>  >         The OCI driver should not depend in nothing but OCI apart from
>>>  >         GDAL/OGR stuff.
>>>  >         Regards,
>>>  >         Ivan
>>>  >             <mailto:gdal-dev at lists.osgeo.**org<gdal-dev at lists.osgeo.org>
>>>  >              Subject: [gdal-dev] Problem Compiling with Oracle
>>>  >             (--with-oci)
>>>  >              Sent: Jun 20 '11 17:43
>>>  >              I'm trying to compile GDAL/OGR with support for
>>>  >             Oracle/OCI. I have the
>>>  >              full oracle 11g server installed on CentOS 5.3.
>>>  >              # configure --with-oci=/opt/oracle/**
>>> product/11.2.0/dbhome_1/
>>>  >              # make
>>>  >              libtool:.....
>>>  >              g++:
>>>  >             /ade/smayer_perl_510/perl_**source/expat_home/lib/**
>>> libexpat.so:
>>>  >             No
>>>  >              such file or directory
>>>  >              I think this path might be from the person who compiled
>>>  >             the OCI
>>>  >              libraries for oracle 11? I have nothing remotely like it
>>>  >             on my system.
>>>  >              If I add --with-expat=no to my configure line I get
>>>  >             errors during
>>>  >              linking about undefined references to XML_... so I'm
>>>  >             guessing the linked
>>>  >              OCI drivers need the expat lib linked in.
>>>  >              I added /opt/oracle/product/11.2.0/**dbhome_1/lib to my
>>>  >             LD_LIBRARY_PATH,
>>>  >              and there is a libexpat.so.1.5.2 there, as well as my
>>>  >              /lib/libexpat.so.0.5.0 which is from my CentOS standarad
>>>  >             RPMS:
>>>  >              # rpm -qa | grep expat
>>>  >              expat-1.95.8-8.2.1
>>>  >              expat-devel-1.95.8-8.2.1
>>>  >              I also tried
>>>  >             --with-expat=/opt/oracle/**product/11.2.0/dbhome_1/ but
>>> there
>>>  >              are no headers there, among other problems.
>>>  >              How can I get this to work?
>>>  >              Thanks,
>>>  >              Chris
>>>  >              ______________________________**_________________
>>>  >              gdal-dev mailing list
>>>  >              gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.**
>>> org <gdal-dev at lists.osgeo.org>>
>>>  >              http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
>>>  >     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.**org<gdal-dev at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110621/7c86be18/attachment.html
