[gdal-dev] ogr2ogr.java s57 conversion
Robert Naugle bobbynaugs at gmail.com
Wed Jun 22 13:18:51 EDT 2011
Hi Even, welcome back.
A fair suggestion, but -skipfailures is the first argument in my argument
list. Even so, the test for skipfailures comes AFTER the call
to CreateFeature(...) which is where I get a *java.lang.RuntimeException:
OGR Error: Unsupported geometry type. *This obviously stops all conversion
in it's tracks.
I could be wrong about what is causing the CreateFeature to fail, all I know
is that it happens as soon as the layer is asked to create a feature of a
new geometry type.
On Wed, Jun 22, 2011 at 1:04 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le mercredi 22 juin 2011 18:48:34, Robert Naugle a écrit :
> > Oliver,
> > Thanks much for your help, and with the link. I thought I would share my
> > progress:
> > The first thing I tried was moving the csv files (s57attributes.csv and
> > s57objectclasses.csv) into the working directory. Success! (sort of...)
> > ogr2ogr.java found all the layers in the s57 chart file. However, the
> > layers appeared to be empty :(
> > Now I know that your suggestion was to set the environment variables
> within
> > the java environment, and that would probably help, but due to the use of
> > JNI in the implementation of ogr2ogr in java, and the desire for a
> working
> > JavaWebStart application later on, that path is beyond my capabilities.
> > So...
> > I did a little digging to see why the layers were empty. Layer
> translation
> > was failing when creating fields for the attributes in the s57 chart.
> > Specifically, the LNAM_REFS and FFPT_RIND fields. I modified ogr2ogr.java
> > to just skip these fields and started to find objects in the layers!
> > Now I am dealing with 'OGR Error: Unsupported geometry type', when
> loading
> > more than one geometry type into a shapefile, which I know is against the
> > rules, but it seems like the cpp ogr2ogr did a better job of handling
> these
> > sorts of errors. I believe this can be helped with some argument
> > manipulation...
> You just need to add "-skipfailures" as a command line argument, as you'd
> do
> with the C++ version of ogr2ogr. The LNAM_REFS and FFPT_RIND fields are of
> type
> StringList and IntegerList, which is not supported by shapefiles. And yes a
> shapefile only supports one geometry type per shapefile. -skipfailures
> should
> skip geometries that are not of the right type.
Bob Naugle
(410) 903-6604
robertjnaugle at gmail.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110622/c5f83681/attachment.html
