[gdal-dev] Re: Is it possible for gdal_translate to perserve the external georeferencing information?
conant conan_tang at hotmail.com
Wed Jun 22 22:54:05 EDT 2011
Thank you Frank!
Here it is the xml file. Yes, it seems that gdalinfo detected the xml file
but it did not read it. Any suggestion?
Cheers,
Nuo
 <?xml version="1.0" encoding="utf-8" ?>
- <GeodataXform xsi:type="typens:PolynomialXform"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:typens="http://www.esri.com/schemas/ArcGIS/9.3">
  <PolynomialOrder>1</PolynomialOrder>
- <SpatialReference xsi:type="typens:ProjectedCoordinateSystem">
<WKT>PROJCS["GDA_1994_MGA_Zone_56",GEOGCS["GCS_GDA_1994",DATUM["D_GDA_1994",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",10000000.0],PARAMETER["Central_Meridian",153.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",28356]]</WKT>
  <XOrigin>-5120900</XOrigin>
  <YOrigin>1900</YOrigin>
  <XYScale>450445547.391054</XYScale>
  <ZOrigin>-100000</ZOrigin>
  <ZScale>10000</ZScale>
  <MOrigin>-100000</MOrigin>
  <MScale>10000</MScale>
  <XYTolerance>0.001</XYTolerance>
  <ZTolerance>0.0002</ZTolerance>
  <MTolerance>0.0002</MTolerance>
  <HighPrecision>true</HighPrecision>
  <WKID>28356</WKID>
  </SpatialReference>
- <SourceGCPs xsi:type="typens:ArrayOfDouble">
  <Double>1.43509557927502</Double>
  <Double>21.8059086384888</Double>
  <Double>10.5531682700964</Double>
  <Double>13.9188303527086</Double>
  <Double>1.2382854426487</Double>
  <Double>2.09871099550583</Double>
  <Double>1.78786552737847</Double>
  <Double>14.19710378737</Double>
  <Double>7.75189289608807</Double>
  <Double>10.6810040785713</Double>
  </SourceGCPs>
- <TargetGCPs xsi:type="typens:ArrayOfDouble">
  <Double>553474.234991123</Double>
  <Double>6882326.40584856</Double>
  <Double>555706.544654901</Double>
  <Double>6880424.58199324</Double>
  <Double>553444.322276391</Double>
  <Double>6877511.19974413</Double>
  <Double>553559.261993501</Double>
  <Double>6880474.91066252</Double>
  <Double>555020.786503956</Double>
  <Double>6879624.65684812</Double>
  </TargetGCPs>
  </GeodataXform>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Is-it-possible-for-gdal-translate-to-perserve-the-external-georeferencing-information-tp6498773p6506986.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
