[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Antonio Valentino antonio.valentino at tiscali.it
Sat Jun 25 06:48:14 EDT 2011
Hi Rodolfo,
can you please confirm that the data type of PALSAR Level 1.5 products
should be GDT_UInt16 and not GDT_Int16 as in current implementation?
If so I will file a ticket with a patch for fixing the issue.
thanks
Il 17/06/2011 21:28, Rodolfo Bonnin ha scritto:
> Hello all,
> I'm just working with some JAXAPalsar images, and I've discovered that
> there is no retrieval of the coordinate system metadata retrieval in
> the current driver, the driver documentation says georeferencing is
> only supported in level 1.5.
> Has anyone tried to implement the feature for this lower level? I have
> gathered some good information about how this could be done, but in
> order to exempt myself to repeat effort, I prefer to consult the list
> beforehand.
> Many thanks in advance.
Antonio Valentino
