[gdal-dev] Re: Michigan GeoRef - Michigan Oblique Mercator - EPSG:3078
Howard Y hayamaguchi at gmail.com
Sun Jun 26 13:46:47 EDT 2011
Thank you for the suggestions, Steve.
The projection parameters for the list you derived are pretty much the same
as the PROJ4 format of EPSG:3078, with the exception of the display unit (m
vs ft) and the datum (NAD27 vs NAD83).  I've tried most of them (but not the
NAD27 versions), and I've also tried my own hand in cranking out the
PROJ4-type parameters based on Michigan state's definition of GeoRef, but
none of them worked.
Looking at the 2007 thru 2009 threads in this forum, it appears that the
problem lies in the difference between "Oblique Mercator" and something
called "Hotine Oblique Mercator," with the "Hotine" version being the one
that GeoRef apparently uses.  But that's way beyond my level of
comprehension, and hence my appeal to the folks in this forum.  Past appeals
by others to developers of QGIS, for example, have always resulted in their
suggestion to post a request for a fix here.
Thanks again for your input!  Cheers!
Howard
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Michigan-GeoRef-Michigan-Oblique-Mercator-EPSG-3078-tp6517423p6517746.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
