[gdal-dev] datum projection info in ecw
Carl Anderson carl.anderson at vadose.org
Tue Jun 28 00:48:11 EDT 2011
Nick,
Does gdalinfo not give you enough information?
C.
On Mon, Jun 27, 2011 at 9:09 PM, <nicholas.g.lawrence at tmr.qld.gov.au> wrote:
> Hello all,
> Does anyone know where the datum and projection information is stored
> inside an ecw?
> Kind regards,
> Nicholas Lawrence*
> Senior Spatial Science Officer | Darling Downs Region / Toowoomba Office*
> Assets & Operations* Division | Department of Transport and Main Roads
> Floor 1 | Toowoomba - Phillip Street | 1-5 Phillip Street (cnr Clopton
> Street) | Toowoomba Qld 4350
> PO Box 645 | Toowoomba Qld 4350
> P: (07) 46390764 | F: (07) 46390750
> E: nicholas.g.lawrence at tmr.qld.gov.au
> W: www.tmr.qld.gov.au*
> Tomorrow's Queensland: strong, green, smart, healthy and fair –
> www.towardQ2.qld.gov.au*
> P| Please consider the environment before printing this email
> WARNING: This email (including any attachments) may contain legally
> privileged, confidential or private information and may be protected by
> copyright. You may only use it if you are the person(s) it was
> intended to be sent to and if you use it in an authorised way. No one
> is allowed to use, review, alter, transmit, disclose, distribute, print
> or copy this email without appropriate authority.
> If this email was not intended for you and was sent to you by mistake,
> please telephone or email me immediately, destroy any hardcopies of
> this email and delete it and any copies of it from your computer
> system. Any right which the sender may have under copyright law, and
> any legal privilege and confidentiality attached to this email is not
> waived or destroyed by that mistake.
> It is your responsibility to ensure that this email does not contain
> and is not affected by computer viruses, defects or interference by
> third parties or replication problems (including incompatibility with
> your computer system).
> Opinions contained in this email do not necessarily reflect the
> opinions of the Department of Transport and Main Roads,
> Maritime Safety Queensland or endorsed organisations utilising
> the same infrastructure.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Carl Anderson, GISP
canderson at spatialfocus.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110628/830dbd12/attachment.html
